Hello.
I have tried to edit a script found in another topic to suit my needs but i can't get it to work the way i want to.
layer2dwg
(defun c:lsave(/ actDoc layCol docName dwgName actSel fCount)
 (vl-load-com)
 (defun BrowseFolder (/ ShlObj Folder FldObj OutVal)
 (vl-load-com)
 (setq
   ShlObj (vla-getInterfaceObject
      (vlax-get-acad-object)
      "Shell.Application"
   Folder(vlax-invoke-method ShlObj 'BrowseForFolder 0
       "Select Folder to create files" 0)
 (vlax-release-object ShlObj)
 (if Folder
     (setq
 FldObj (vlax-get-property Folder 'Self)
 OutVal (vlax-get-property FldObj 'Path)
     (vlax-release-object Folder)
     (vlax-release-object FldObj)
     OutVal
 (setq actDoc(vla-get-ActiveDocument
       (vlax-get-acad-object))
   actSel(vla-get-ActiveSelectionSet actDoc)
   layCol(vla-get-Layers actDoc)
   docName(vla-get-Name actDoc)
   fCount 0
   ); end setq
 (if
   (setq wntPath
      (BrowseFolder))
 (vlax-for lay layCol
   (setq layName(vla-get-Name lay)
     dwgName
      (strcat wntPath "\\"
          (vl-filename-base docName)
           " - " layName ".dwg")
     ); end setq
(vla-clear actSel)(vla-erase actSel)
(vla-Select actSel acSelectionSetAll nil nil
 (vlax-safearray-fill
   (vlax-make-safearray vlax-vbInteger '(0 . 0))
 ) ; end vla-safearray-fill
   (vlax-make-safearray vlax-vbvariant '(0 . 0))
    (list layName)
) ; end vla-select
   (if(/= 0(vla-get-Count actSel))
     (vla-WBlock actDoc dwgName actSel)); end if
   (setq fCount(1+ fCount))
   ); end vlax-for
 ); end progn
   ); end if
 (princ
   (strcat "\*** "
       (itoa fCount)
       " files were created *** "))
 ); end of c:lsave
I have poked the "WBlock" line in different ways but i can't get FBXEXPORT to work in the script.
Any help is appreciated.
There is no 'vla' method for exporting to FBX. You will have to work with the -FBXEXPORT command I think.
I'm just getting errors about "export" / "fbxexport" function not existing when trying to run it in a lsp script. Any ideas for fixing the script?
I cannot help you with a detailed answer as I use BricsCAD 16 instead of AutoCAD. But you will have to analyse how the -FBXEXPORT command works and then write code containing something like this:
(command "_.-FBXEXPORT" ...)
Your code sample would have to be completely rewritten.
Try the following:
(defun c:lay2fbx ( / cmd def dir sel spc )
   (setq cmd (getvar 'cmdecho)
         dir (getvar 'dwgprefix)
         spc (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))
   (setvar 'cmdecho 0)
   (while (setq def (tblnext "layer" (null def)))
       (if
           (and
               (zerop (logand (cdr (assoc 70 def)) 21))
               (setq sel (ssget "_X" (list (cons 8 (cdr (assoc 2 def))) spc)))
           (vl-cmdf "_.-fbxexport" "_S" sel "" "_A" "_E" (LM:uniquefilename (strcat dir (cdr (assoc 2 def)) ".fbx")))
   (setvar 'cmdecho cmd)
;; Unique Filename  -  Lee Mac
;; Returns a filename suffixed with the smallest integer required for uniqueness
(defun LM:uniquefilename ( fnm )
   (if (findfile fnm)
       (apply
          '(lambda ( pth bse ext / tmp )
               (setq tmp 1)
               (while (findfile (setq fnm (strcat pth bse "(" (itoa (setq tmp (1+ tmp))) ")" ext))))
           (fnsplitl fnm)
   fnm
Lee, if my eyes don't fool me, you forgot to add (fnsplitl fnm) sub function... I know it's dummy, but anyway, it's just me and my remark... Happy Christmas holidays and new year...
No - fnsplitl is a standard AutoLISP function :thumbsup:
Happy New Year to you too.
Try the following: [#CODE]
Works perfectly. Tyvm :D:thumbsup:
That LM:uniquefilename is cleverly written, I like it!
Thank you Grrr! :)
  • 4 years later...
Very nice...
I am searching for this..
I wrote a simple autolisp shortcut n use it by freezing each layer n giving one file name every time..
You saved my time...
Thanks you 👍
Edited by Jnanashakthi
