khoshravan Posted December 24, 2016 Share Posted December 24, 2016 In the attached drawing, I want the angle between planes ABEH and ACDB to be 90 degrees. How should I define the pyramid to obtain that shape? piramid.dwg Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 24, 2016 Share Posted December 24, 2016 Can't find plane ABEH or points E and H. Where are they? Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 25, 2016 Share Posted December 25, 2016 I am not sure what you mean by a plane other than the ABCD plane. Any way, the only 90 degree angles in a pyramid are the four corners of the base. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 25, 2016 Share Posted December 25, 2016 (edited) From the sound of things, you want a right pyramid, I think you want to use LOFT to POINT. A pyramid (from Greek: πυραμίς pyramis) is a structure whose outer surfaces are triangular and converge to a single point at the top, I should add that I haven't opened the attached drawing, and it sounds like you want a four sided based right trangle, same technique to do it. Edited December 25, 2016 by Dadgad Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 25, 2016 Share Posted December 25, 2016 Or use the Primitive: Pyramid. Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 25, 2016 Share Posted December 25, 2016 As Dana W said the four corners on the base can be 90 degerees, if you have 90 degrees between the verticle faces then it will be a cube. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted December 25, 2016 Author Share Posted December 25, 2016 Can't find plane ABEH or points E and H. Where are they? Sorry I uploaded a wrong drawing. In this drawing I want plane OAB to be perpendecular to ABCD plane. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted December 25, 2016 Author Share Posted December 25, 2016 From the sound of things, you want a right pyramid, I think you want to use LOFT to POINT. A pyramid (from Greek: πυραμίς pyramis) is a structure whose outer surfaces are triangular and converge to a single point at the top, I should add that I haven't opened the attached drawing, and it sounds like you want a four sided based right trangle, same technique to do it. Dear Dadgad You are correct. I want a right pyramid. Although your notes are helpful but couldn't get a hint from your notes on how to do it? I am new to 3D and don't know how to do it. The only new command I saw in your reply is loft and I will give it a try. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted December 25, 2016 Share Posted December 25, 2016 (edited) Is this (attached) what you are looking for? If it is, here is what you do: Set your view to "SE isometric" Draw a square 1.42 x 1.42 (A-B-C-D) Extrude the square to 1.25 height. Let's call the new solid a "base body" Let the new upper plane (the one parallel to base A-B-C-D) be a plane A1-B1-C1-D1 Change the UCS to "Front" Draw a polyline D-B1-D1-close Extrude new polyline to 2 units height. Subtract newly created body from the "base body" Change UCS to "Left" Let's a midpont of the edge A1-B1 be "E" point (you can place the "E" point anywhere along the edge) Draw polylines A-E-A1-close and polyline B-E-B1-close Extrude both polylines to 2 units height Subtract the two new solids from "base body" Done. pyramid.dwg Edited December 26, 2016 by paulmcz Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 26, 2016 Share Posted December 26, 2016 (edited) Dear DadgadYou are correct. I want a right pyramid. Although your notes are helpful but couldn't get a hint from your notes on how to do it? I am new to 3D and don't know how to do it. The only new command I saw in your reply is loft and I will give it a try. Create the base of your pyramid. At whichever vertex you want to be the right angle along the Z axis, create a point. Switch to an Isometric perspective, select the Point and move it up orthogonally along the Z axis, to the appropriate distance, representing the height of your pyramid. Start the LOFT command, select the POint option from the commandline prompts, then just follow the prompts, very simple. If you look at my screenshot, you can see the point which is highlighted with a circle, and now selected, above the left most vertex of the triangle on the left side of the screenshot. Loft to a Point is pretty darned straight ahead, as long as you are in an isometric perspective, so you can see what is going on. Edited December 27, 2016 by Dadgad Quote Link to comment Share on other sites More sharing options...
GP_ Posted December 27, 2016 Share Posted December 27, 2016 (edited) How should I define the pyramid to obtain that shape? From your dwg: Edited December 27, 2016 by GP_ Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2016 Share Posted December 27, 2016 I'd like to know why you felt it was necessary to set your crosshairs in an isometric plane in the drawing attached to post #1? Care to explain? Do you know how to reorient the UCS? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 28, 2016 Share Posted December 28, 2016 Using Gp method No ucs etc create POINT mid point of base line use properties change Z of point, Ctrl pick top pyramid pick Node all done then erase node. Autocad always has so many ways to do one task. Also thought about 3dfaces convert to surface convert to solid. Not sure how to pick top of pyramid point if it was to be automated.. Quote Link to comment Share on other sites More sharing options...
ADSK2007 Posted December 30, 2016 Share Posted December 30, 2016 Here is how you do it - See attached Adsk Quote Link to comment Share on other sites More sharing options...
