emil-m Posted December 20, 2016 Posted December 20, 2016 Hi, I want to make a script who draw circles in multiple Points. The Points are automaticly made in a extension to autocad. All the Points are in same layers. It´s around 200 to 1000 Points in the drawing. My first issue is to find a commando who draw circles, with basepoints in all Points. Does anyone know the appropriate command for me? Regards, Emil Quote
paulmcz Posted December 20, 2016 Posted December 20, 2016 This is what I use. (defun c:ic (/ a b c r d n p d1 d2 e1 cl oerr osn) (setq osn (getvar "osmode")) (setvar "cmdecho" 0) (setq cl (getvar "clayer")) (if c () (setq c 1.0) ) (princ "\n Circle diameter < ") (princ c) (princ " > ? ") (setq b (getdist)) (if (= b nil) (setq b c) (setq c b) ) (setq r (/ b 2)) (princ "\n Select nodes ") (setq a (ssget '((0 . "POINT")))) (setq d (sslength a)) (setq d1 d) (repeat d (setq d2 (1- d1)) (setq n (ssname a d2)) (setq e1 (entget n)) (setq p (cdr (assoc 10 e1))) (entmake (list (cons 0 "CIRCLE") (cons 6 "BYLAYER") (cons 8 cl) (cons 10 p) (cons 40 r) (cons 210 (list 0.0 0.0 1.0)) ) ) (entdel n) (setq d1 d2) ) (setvar "osmode" osn) (princ) ) Quote
BIGAL Posted December 21, 2016 Posted December 21, 2016 Maybe a slight simplification of code (setq d (sslength a)) (setq d1 d) (repeat d (setq d2 (1- d1)) (setq n (ssname a d2)) (setq e1 (entget n)) [color=lime](repeat (setq d2 (sslength a)))[/color] [color=lime] (setq e1 (entget (ssname a (setq d2 (- d2 1)))))[/color] Quote
satishrajdev Posted December 21, 2016 Posted December 21, 2016 (edited) Another one (defun c:test (/ a b i) (if (and (setq a (ssget '((0 . "point")))) (setq b (getdist "\nSpecify Circle Radius : ")) ) (repeat (setq i (sslength a)) (entmakex (list (cons 0 "CIRCLE") (assoc 10 (entget (ssname a (setq i (1- i))))) (cons 40 b) ) ) ) ) (princ) ) Edited December 22, 2016 by satishrajdev Quote
Lee Mac Posted December 21, 2016 Posted December 21, 2016 @Satish, Note that: (cons 10 (cdr (assoc 10 <list>))) == (assoc 10 <list>) Quote
Grrr Posted December 21, 2016 Posted December 21, 2016 I remember someone wrote an algorithm for spacing circles within range (not sure if it was Marko). Can't seem to find it right now. Quote
satishrajdev Posted December 22, 2016 Posted December 22, 2016 Lee Mac said: @Satish, Note that: (cons 10 (cdr (assoc 10 <list>))) == (assoc 10 <list>) Thanks you sir. I need to be more focused on this BTW I have updated the code. Quote
emil-m Posted January 2, 2017 Author Posted January 2, 2017 Thanks so much. It works good! satishrajdev said: Another one (defun c:test (/ a b i) (if (and (setq a (ssget '((0 . "point")))) (setq b (getdist "\nSpecify Circle Radius : ")) ) (repeat (setq i (sslength a)) (entmakex (list (cons 0 "CIRCLE") (assoc 10 (entget (ssname a (setq i (1- i))))) (cons 40 b) ) ) ) ) (princ) ) Quote
Lee Mac Posted January 2, 2017 Posted January 2, 2017 FWIW, here's another version which will retain the original properties of the points, and will account for points constructed in any UCS plane: (defun c:p2c ( / c i r s x ) (if (and (setq s (ssget '((0 . "POINT")))) (progn (initget 6) (setq r (getdist "\nSpecify circle radius: ")) ) ) (repeat (setq i (sslength s)) (setq x (reverse (entget (ssname s (setq i (1- i))))) c (assoc 10 x) ) (entmake (subst '(0 . "CIRCLE") '(0 . "POINT") (subst (cons 10 (trans (cdr c) 0 (cdr (assoc 210 x)))) c (reverse (cons (cons 40 r) (vl-remove-if '(lambda ( x ) (member (car x) '(50 102 360))) x) ) ) ) ) ) ) ) (princ) ) Quote
Grrr Posted January 2, 2017 Posted January 2, 2017 Thats some interesting list manipulation Lee! I would remove GCs -1 5 and 100 aswell (just in case). Although it seems that entmake/x ignores them: _$ (entmake (list (cons 0 "POINT") (cons 5 "MyHandle") (cons 100 "AcDbLWPolyline") (cons 62 1) (cons 10 (getpoint)))) ((0 . "POINT") (5 . "MyHandle") (100 . "AcDbLWPolyline") (62 . 1) (10 -38.7621 156.008 0.0)) _$ (entget (entlast)) ((-1 . <Entity name: 7ff678604cc0>) (0 . "POINT") (330 . <Entity name: 7ff6786039f0>) (5 . "24C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 1) (100 . "AcDbPoint") (10 -38.7621 156.008 0.0) (210 0.0 0.0 1.0) (50 . 0.0)) _$ Quote
Lee Mac Posted January 2, 2017 Posted January 2, 2017 Grrr said: Thats some interesting list manipulation Lee! Thanks! Grrr said: I would remove GCs -1 5 and 100 aswell (just in case). I agree with removing the subclass markers in general, as these will cause issues when generating the following entities: ATTRIB (Multiline) ELLIPSE HATCH LWPOLYLINE MTEXT SPLINE XLINE However, it is not necessary to remove DXF groups -1 & 5, as these are always ignored. Quote
