Draw circles in multiple points
emil-m
Hi,
I want to make a script who draw circles in multiple Points. The Points are automaticly made in a extension to autocad. All the Points are in same layers. It´s around 200 to 1000 Points in the drawing.
My first issue is to find a commando who draw circles, with basepoints in all Points.
Does anyone know the appropriate command for me?
Regards,
Emil
This is what I use.
(defun c:ic (/ a b c r d n p d1 d2 e1 cl oerr osn)
 (setq osn (getvar "osmode"))
 (setvar "cmdecho" 0)
 (setq cl (getvar "clayer"))
 (if c
   (setq c 1.0)
 (princ "\n Circle diameter < ")
 (princ c)
 (princ " > ? ")
 (setq b (getdist))
 (if (= b nil)
   (setq b c)
   (setq c b)
 (setq r (/ b 2))
 (princ "\n Select nodes ")
 (setq a (ssget '((0 . "POINT"))))
 (setq d (sslength a))
 (setq d1 d)
 (repeat d
   (setq d2 (1- d1))
   (setq n (ssname a d2))
   (setq e1 (entget n))
   (setq p (cdr (assoc 10 e1)))
   (entmake (list (cons 0 "CIRCLE")
	   (cons 6 "BYLAYER")
	   (cons 8 cl)
	   (cons 10 p)
	   (cons 40 r)
	   (cons 210 (list 0.0 0.0 1.0))
   (entdel n)
   (setq d1 d2)
 (setvar "osmode" osn)
Maybe a slight simplification of code
 (setq d1 d)
 (repeat d
   (setq d2 (1- d1))
 [color=lime](repeat (setq d2 (sslength a)))[/color]
[color=lime]    (setq e1 (entget (ssname a (setq d2 (- d2 1)))))[/color]
Another one
(defun c:test (/ a b i)
 (if (and (setq a (ssget '((0 . "point"))))
   (setq b (getdist "\nSpecify Circle Radius : "))
   (repeat (setq i (sslength a))
     (entmakex
      (assoc 10 (entget (ssname a (setq i (1- i)))))
      (cons 40 b)
Edited by satishrajdev
@Satish, Note that:
(cons 10 (cdr (assoc 10 <list>))) == (assoc 10 <list>)
I remember someone wrote an algorithm for spacing circles within range (not sure if it was Marko).
Can't seem to find it right now.
@Satish, Note that:
Thanks you sir. I need to be more focused on this :oops:
BTW I have updated the code.
  • 2 weeks later...
Thanks so much.
It works good!
Another one
     (entmakex
         (cons 40 b)
FWIW, here's another version which will retain the original properties of the points, and will account for points constructed in any UCS plane:
(defun c:p2c ( / c i r s x )
   (if (and (setq s (ssget '((0 . "POINT"))))
               (initget 6)
               (setq r (getdist "\nSpecify circle radius: "))
       (repeat (setq i (sslength s))
           (setq x (reverse (entget (ssname s (setq i (1- i)))))
                 c (assoc 10 x)
           (entmake
               (subst '(0 . "CIRCLE") '(0 . "POINT")
                   (subst (cons 10 (trans (cdr c) 0 (cdr (assoc 210 x)))) c
                       (reverse
                           (cons (cons 40 r)
                               (vl-remove-if '(lambda ( x ) (member (car x) '(50 102 360))) x)
Thats some interesting list manipulation Lee! :thumbsup:
I would remove GCs -1 5 and 100 aswell (just in case). Although it seems that entmake/x ignores them:
_$ (entmake (list (cons 0 "POINT") (cons 5 "MyHandle") (cons 100 "AcDbLWPolyline") (cons 62 1) (cons 10 (getpoint))))
((0 . "POINT") (5 . "MyHandle") (100 . "AcDbLWPolyline") (62 . 1) (10 -38.7621 156.008 0.0))
_$ (entget (entlast))
((-1 . <Entity name: 7ff678604cc0>) (0 . "POINT") (330 . <Entity name: 7ff6786039f0>) (5 . "24C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 1) (100 . "AcDbPoint") (10 -38.7621 156.008 0.0) (210 0.0 0.0 1.0) (50 . 0.0))
_$
Thanks!
I agree with removing the subclass markers in general, as these will cause issues when generating the following entities:
ATTRIB (Multiline)
ELLIPSE
HATCH
LWPOLYLINE
MTEXT
SPLINE
XLINE
However, it is not necessary to remove DXF groups -1 & 5, as these are always ignored.
