Sir any lisp program to create separate layout tabs with same page from multiple layout on a layout.
I need for road layout plan and profile .
Thanks
Thanks
Expand
There's no such thing as "multiple layout on a layout"!
AutoCAD Help About Layouts section is a good place to start:
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-93E88E2A-3BA8-40C1-8BF5-9A50B716EB34
How did you create this mess? While you could create a separate Page Setup for each of those since you can only assign one Page Setup for each Layout you should still make duplicate layouts for each of them allowing you to use the publish command and to make plotting easier as you wouldn't have to change Page Setups to plot each sheet.
