flem snopes Posted January 9, 2009 Posted January 9, 2009 I'm in AutoCad 2009 block editor trying to modify a leader in the properties box. I've got 4 leaders in the block and only one of them is acting squirrely. The Misc. block has a type property with 4 choices as follows: Line with no arrow Spline with no arrow Line with arrow Spline with arrow It's currently showing Line with no arrow, I want a line with an arrow. I select Line with arrow and when I tab out of the box it reverts to Line with no arrow. The other 3 leaders are acting normally. Any suggestions? Quote
chulse Posted January 10, 2009 Posted January 10, 2009 There is proably not enough room on the line for the arrow. Try making the line longer. Quote
flem snopes Posted January 12, 2009 Author Posted January 12, 2009 DOH! That was it. I'd tried everything else. Thanks. Quote
jokermtb Posted March 28, 2014 Posted March 28, 2014 Its usually a dimscale vs ltscale issue. Often the dimscale gets reset to some value that is big, or small enough that while the arrows are appearing they're usually too big or small to appear. Try playing around with dimscale in wherever you place leader lines (paper or model space)....you'll eventually get the arrows to appear. Quote
