Fullalove Posted January 9, 2009 Posted January 9, 2009 Is there a way to sort a Revit schedule by project phase? What I hope to make possible is the ability to sort both schedules and 3D visual models by phase while only having to change one parameter within the properties of each object. Currently I can adjust both the 'phase', under phasing to allow me to filter my project visually and the likewise change the 'system', under identity to filter my schedules, but what I want is to be able to sort both by changing only one parameter, rather than 'phase' AND 'system'. Any ideas? Thanks Quote
ARCHdoc Posted February 18, 2009 Posted February 18, 2009 Why not create two schedules (or as many as you would like) for each phase you need, Then you need only change the phase to act visually and reference to the shedule as needed. Quote
