Which autocad variable controls the display of dialog box display
when we use below autolisp codes
(note: for most commands which displays dialogs box used at command prompt)
(command "._layer" ......)
(command "._rename" ......)
& so on
Thank you in advance
The variable is CMDECHO, as shown in the screenshot, from my SYSVDLG.
Thank you Dadgad
If i am not wrong, CMDECHO is not the reason for the issue.
Once a faced problem that most of the lisp programs not working, and traced out that the programs
having commands which open dialogs doesn't work. - example : (command "._layer" ....)
After doing "Reset Settings to Default" issue was cleared.
Not able to find the actual system variable.
Sorry about that, I am ill-lisperate, but thought that was the one. :huh:
Glad you were able to get it sorted! :)
FILEDIA is what you looking for
but it is better to add - next to command
(command "_.[b]-[/b]layer" ......)
(command "_.[b]-[/b]rename" ......)
instead of
May be this issue due to some bug.
Is there any way to display dialog box while we type following at command prompt.
(command "._layer")
or
(command "._rename")
FILEDIA and CMDDIA doesn't do this
Already i started to practice
(command "_.-layer" ......)
(command "_.-rename" ......)
Thank you Roy and asos
