arcaliza Posted December 4, 2016 Posted December 4, 2016 Hi.. I draw a circle inside the hath, and I couldn't trim the hath inside the circle. 1-My hatch and circle elevation are at the same level. 2-I tried both Associative and non-Associative hatch. 3-The layers are not locked. you can find the attached drawing here. SAMPLE-TRIM-HATCH.dwgUnavailable Thanks Quote
Spaj Posted December 4, 2016 Posted December 4, 2016 arcaliza said: Hi.. I draw a circle inside the hath, and I couldn't trim the hath inside the circle. 1-My hatch and circle elevation are at the same level. 2-I tried both Associative and non-Associative hatch. 3-The layers are not locked. you can find the attached drawing here. [ATTACH]60018[/ATTACH] Thanks Hi Not sure you can just trim hatch without exploding. Rather Edit Hatch and Add: Selected Objects. Quote
Dana W Posted December 4, 2016 Posted December 4, 2016 DO NOT explode a hatch, ever. It should be trimmable, but there are from time to time, program issues with hatches even in the newer versions with the "good" hatch editor. If you can't trim it, erase the hatch, draw the inner circle and re-hatch. Quote
welldriller Posted December 5, 2016 Posted December 5, 2016 Dana W said: DO NOT explode a hatch, ever. It should be trimmable, but there are from time to time, program issues with hatches even in the newer versions with the "good" hatch editor. If you can't trim it, erase the hatch, draw the inner circle and re-hatch. The best advise you will ever get on this one. Quote
ReMark Posted December 5, 2016 Posted December 5, 2016 You can trim the hatch but it must be non-associative to do so. I tested this in both AutoCAD 2015 and AutoCAD 2017. Quote
