bend Posted November 30, 2016 Posted November 30, 2016 Hello, I'm very new to LISP and wanted a hand with writing a simple script to copy a line and change the layer to a specific layer. It going from Layer "50" to "TRAV" and I wanted this changed line copied on to of itself. I have a pretty good understanding of TCL as I have written in that when using Surpac but I'm at a new job now and trying to educate myself with a few basic but useful scripts. Any help will be great. Quote
BIGAL Posted November 30, 2016 Posted November 30, 2016 There are various ways a couple of examples using lisp. Copy and paste to the command line then just type copyself. (defun c:copyself () (setq Newlyr (getstring "Enter destination layer ")) (command "copy" (Entsel) "" '(0 0) '(0 0));;creates a copy on same layer (command "-chprop" (entlast) "" "LA" NewLyr "");;changes orig to new layer ) (defun c:copyself () (setq Newlyr (getstring "Enter destination layer ")) (vla-copy (vlax-ename->vla-object (car (entsel)))) ;creates a copy on same layer (vla-put-layer (vlax-ename->vla-object (entlast)) newlayer) ;changes copy to new layer ) Some more help http://www.cadtutor.net/forum/showthread.php?98213-Copy-text-into-same-place-but-in-different-layer Quote
Lee Mac Posted November 30, 2016 Posted November 30, 2016 I assume you are aware of the built-in COPYTOLAYER command? Quote
bend Posted December 2, 2016 Author Posted December 2, 2016 Hello, Thanks very much for this, although I am getting the following. "Select object: Error: ActiveX Server returned an error: Parameter not optional" The destination layer will always be TRAV is it possible to have this fixed? B Quote
Grrr Posted December 2, 2016 Posted December 2, 2016 bend said: Hello, Thanks very much for this, although I am getting the following. "Select object: Error: ActiveX Server returned an error: Parameter not optional" The destination layer will always be TRAV is it possible to have this fixed? B Obviously: "You are passing a nil argument to some vla-whatever function." So there was a typo: (setq [color="red"]Newlyr [/color](getstring "Enter destination layer ")) (vla-copy (vlax-ename->vla-object (car (entsel)))) ;creates a copy on same layer (vla-put-layer (vlax-ename->vla-object (entlast)) [color="red"]Newlyr[/color]) ;changes copy to new layer Quote
