pol_4792 Posted November 25, 2016 Share Posted November 25, 2016 Hello, guys! So, I have this 3D view of my project and my personal layout on the same .dwg file. Attached herewith is a screenshot of the 3D view, that I want to place on my layout, and my own personal layout. Can somebody please give me a step-by-step procedure on how to this. An example is also attached for your reference. Thank you very much & I appreciate whatever help you can give me Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 25, 2016 Share Posted November 25, 2016 In order to see what you created back in model space your layout will need at least one viewport. This can be done by using the MVIEW command. A viewport is merely a window through which model space objects are viewed. You can also assign a scale to a viewport if so desired. I suggest that you create a new layer called VPorts and give it a color other than white/black so it is distinguishable from your title block and border. Set the layer to "no print" in your Layer Properties Manager. After you have the viewport set up the way you want (with the exact view you want) lock the display so the viewport scale is not inadvertently changed. It should be noted that if you are utilizing a layout then it makes sense for your titleblock and border to be in the layout itself and not in model space. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 26, 2016 Share Posted November 26, 2016 Just one more step to Remarks good advice double click go into layout and use Vpoint to set a simple viewing angle. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 26, 2016 Share Posted November 26, 2016 Or......you can select one of the four standard isometric views right off the Ribbon. Quote Link to comment Share on other sites More sharing options...
