tzframpton Posted November 24, 2016 Posted November 24, 2016 The way one can work with files is something to consider. My wifi was temporary out so my Revit says : failure / abort!Not able to save anything anymore, model crash, shuts down program leaving me with a big pile of **** unclear error messsages. So maybe TZ, you understand that i may find working offline with smaller models not a bad idea for working moral .. I can understand the position on wanting to work on a single file, detached from a "server file", offline. I can also understand the other position, where connectivity is virtually constant, and true collaborative team workflow, and the majority of companies have a demand for multi-user access to a living model. To reprogram the Workshare feature for the 0.0001% of the users who are single-access users, that need to work offline for a very short amount of time because of a hardware issue just isn't in the program's best interest. And if you are in fact a single-access user, then don't Workshare the model and problem solved. -TZ Quote
halam Posted November 24, 2016 Posted November 24, 2016 The reason why i have to work with wifi on a project that is on the network is because, as you may know, rvt can break up huge models into worksets, ONLY if you work with rvt as 'central file'. I never understood the logic why this can't be done with none-central saved file. Quote
tzframpton Posted November 25, 2016 Posted November 25, 2016 The reason why i have to work with wifi on a project that is on the network is because, as you may know, rvt can break up huge models into worksets, ONLY if you work with rvt as 'central file'. I never understood the logic why this can't be done with none-central saved file.You can create a Workshared central model on your local machine. It doesn't have to be on a network at all. Quote
tzframpton Posted November 25, 2016 Posted November 25, 2016 thanks for this briljant idea..Lol, is this sarcasm, or did you really not know this? Quote
halam Posted November 25, 2016 Posted November 25, 2016 Off course I know this. Saving a central file local creates many other difficulties. Probably bigger treats. Forgot to mention the projects are big and with more designers involved Quote
tzframpton Posted November 25, 2016 Posted November 25, 2016 Off course I know this. Saving a central file local creates many other difficulties. Probably bigger treats. Forgot to mention the projects are big and with more designers involvedNot sure why all the sudden you got snippy. Was just trying to assist by throwing out all possible options. I did not mean to offend. Good day. -TZ Quote
