I never said you could export as a .STL file since you are working with a release of AutoCAD that does not have a native command to convert the surfaces to a solid. I'll take a look at your drawing once I get back to my CAD computer.
  • Replies 21
  • george74
    9
  • ReMark
    7
  • Dadgad
    3
  • paulmcz
    2
Posted Images
I have attached a drawing saved in AutoCAD 2000 .dwg file format. It contains a single 3D solid in the shape you wanted.
In the future try to avoid overriding the assigned color of a layer unless it is absolutely necessary. It just makes life a whole lot easier for everyone.
TwistedHex.dwg
Thank you so much, ReMark ... I guess I must move asap to higher version of Autocad so I will be able to this kind of objects by my self.
I sincerly appretiate your help, All the best, Gregor
