hidxb123 Posted November 9, 2016 Author Posted November 9, 2016 Now working :D:D:D:D Thank you Leemac Sir. for your valuable time, this happened because i don't have any programing knowledge , i will try to learn but i don't know where i get a proper training Thank you BIGAL also for your reply. If you are changing ATTREQ to 0, you should not supply the attribute value: (defun c:dee ( / fname ) (mapcar 'setvar '("cmdecho" "insunits" "dimasz") '(0 4 3.0)) (if (findfile (setq fname "c:\\hpc\\DE.dwg")) (command "_.-insert" fname "_S" 1.4 "_R" 0.0 "_non" '(7.6911 3.3174)) ) ) You also no longer require the ENTER & rotation responses, as these have already been supplied ("_S" 1.4 and "_R" 0.0). Please take some time to study the comments in my posts, and also manually enter the prompts for the -INSERT command at the command-line so that you are aware of how your program works. I see that you have also changed the function definition to 'c:dee', therefore, it will need to be evaluated as such: _.open *file* (load "DEE.lsp" nil) (if c:DEE (c:DEE)) _.qsave _.close Quote
asos2000 Posted November 9, 2016 Posted November 9, 2016 http://www.afralisp.net/index.php http://www.cadmagazine.net/content.php (Arabic) http://lee-mac.com/tutorials.html http://web2.airmail.net/terrycad/Tutorials/MyDialogs.htm#IntroAutoLISP Quote
Lee Mac Posted November 9, 2016 Posted November 9, 2016 Now working :D:D:D:D Thank you Leemac Sir. for your valuable time, this happened because i don't have any programing knowledge , i will try to learn but i don't know where i get a proper training You're welcome - I'm glad the program is now working for you. Good luck with your programming studies. Quote
marioo Posted October 19, 2022 Posted October 19, 2022 On 11/9/2016 at 8:22 PM, Lee Mac said: You're welcome - I'm glad the program is now working for you. Good luck with your programming studies. _.open *file* -INSERT D:\@BLOCK\TB-ASBUILTSHOPDWG.dwg (COMMAND \E "RESUME") ASC TB1 ATTSYNC N TB-ASBUILTSHOPDWG _.QSAVE CLOSE can you help me sir? how i can separately command after ATTSYNC TB-ASBUILTSHOP DWG & qsave command in my autocad that one become in one line. Quote
BIGAL Posted October 20, 2022 Posted October 20, 2022 Should this be "TB-ASBUILTSHOP.DWG", if its a script consider doing a line by line this can force the Enter needed as the attsync is reading a fie name including all spaces up to end of line. If its a menu style ^c^c ...Attsync "TB-ASBUILTSHOP.DWG"; _.QSAVE CLOSE not tested. Quote
marioo Posted October 20, 2022 Posted October 20, 2022 4 hours ago, BIGAL said: Should this be "TB-ASBUILTSHOP.DWG", if its a script consider doing a line by line this can force the Enter needed as the attsync is reading a fie name including all spaces up to end of line. If its a menu style ^c^c ...Attsync "TB-ASBUILTSHOP.DWG"; _.QSAVE CLOSE not tested. thank you for your suggestion, i try but still can't. luckily i see on lsp, already can like this. _.open *file* -INSERT D:\@BLOCK\TB-ASBUILTSHOPDWG.dwg (COMMAND \E "RESUME") ASC TB1 (command "attsync" "n" "TB-ASBUILTSHOPDWG") _.QSAVE _.CLOSE Quote
BIGAL Posted October 20, 2022 Posted October 20, 2022 My take _.open *file* -INSERT "D:/BLOCK/TB-ASBUILTSHOPDWG.dwg" (COMMAND \E "RESUME") ASC TB1 (command "attsync" "n" "TB-ASBUILTSHOP DWG") _.QSAVE _.CLOSE Quote
