Stuart70 Posted November 3, 2016 Posted November 3, 2016 Hi all. Needing some help here. Switched on Architecture 09 this morning and all my toolbars had disappeared. I've managed to get the ribbon back and revert to good old toolbars (type MENUBAR into command line, then change setting to 1). It's taken a while to get the screen back to where it should be, but I've lost the Design option from the menu bar. There was a pull down option that let me choose walls, roofs, floors etc but it's gone. I'm sure my workspace was always 2D drafting but I've looked everywhere, including Classic AutoCAD. How do I get the pulldown menu back? And how do I draw 3d walls without it?! Honestly, I'm so close to moving to Sketchup. Quote
tzframpton Posted November 3, 2016 Posted November 3, 2016 Hi all. Needing some help here. Switched on Architecture 09 this morning and all my toolbars had disappeared. I've managed to get the ribbon back and revert to good old toolbars (type MENUBAR into command line, then change setting to 1). It's taken a while to get the screen back to where it should be, but I've lost the Design option from the menu bar. There was a pull down option that let me choose walls, roofs, floors etc but it's gone. I'm sure my workspace was always 2D drafting but I've looked everywhere, including Classic AutoCAD. How do I get the pulldown menu back? And how do I draw 3d walls without it?! Honestly, I'm so close to moving to Sketchup. I think you chose the wrong profile. Make sure you start AutoCAD with the Architecture Profile and everything should go back to normal. By simply switching Profiles after "vanilla AutoCAD" profile has been loaded, it will not load the vertical tools, which is why you must close and restart in the proper one. -TZ Quote
Stuart70 Posted November 3, 2016 Author Posted November 3, 2016 I'm clicking on the same desktop icon as usual, no idea what's changed. According to the properties of that shortcut, my target profile is this: "C:\Program Files\AutoCAD Architecture 2009\acad.exe" /ld "C:\Program Files\AutoCAD Architecture 2009\AecBase.dbx" /p "AutoCAD Architecture (UK)" Must confess that I'm not sure if that needs to be changed, nor how to do it. Thanks for your theory, makes sense. Quote
tzframpton Posted November 3, 2016 Posted November 3, 2016 That seems correct. Since you are starting AutoCAD with the *.DBX file, go ahead and try to reapply the Profile and see if that sort of resets everything. -TZ Quote
Stuart70 Posted November 3, 2016 Author Posted November 3, 2016 How do I reapply the profile? By the way, I opened ACAD using the "US Metric" shortcut and everything is where it should be. Looks like your theory is correct so huge thanks for that. I just need to get Architecture (UK) to open properly, but at least I can get on with some work and catch up on the time I've wasted. Quote
tzframpton Posted November 3, 2016 Posted November 3, 2016 How do I reapply the profile?Options > Profiles Tab. Select the Profile and click "Set Current". -TZ Quote
tzframpton Posted November 3, 2016 Posted November 3, 2016 Okay, then I'm at a loss for now. I moved on to Revit many years ago and left the AutoCAD Verticals behind so my memory is faint with these types of issues. Hope someone can jump in to help you solve your problem. -TZ Quote
Stuart70 Posted November 3, 2016 Author Posted November 3, 2016 Okay. And thanks again for your help, much appreciated. Quote
Stuart70 Posted November 3, 2016 Author Posted November 3, 2016 There are a few CUI files in this folder - C:\Users\Stuart\AppData\Roaming\Autodesk\ACD-A 2009\enu\Support If I double click on any of them they open up the program, with the correct profile - except for the CUI file called "aca_UK" When I open that one the "design" option disappears from the menu bar. As TZ suggested earlier, the vertical tools aren't loading. Suggestions are welcome... Quote
