Adding Level value onto survey points in drawing
Hi, ive carried out a survey, points on an existing carpark. Have exported from my TS in .dxf and have successfully loaded into CAD.
Now all the points are just that, points, none of them show a level value on screen. They definitely have a X,Y&Z value to the points as I have ID them but just want it to show each value of Z on the drawing.
Any help appreciated as usual :)
Cheers Liam
Hi
Are you able to extract your observations into a .TXT file of some form? If so, then import your points as COGO points and set the style to display elevations.
Your info says you have 2017 CIV3D so I would use its power and make COGO points then just use a label style to show elevation obviously then you can do contours etc as well.
