Tawez Posted November 2, 2016 Posted November 2, 2016 Hie guys Ive been learning Revit on my own since its not very common in the region i come from.I always download tutorials and follow them. It has been an amazing thing especially coming from a Autocad background. My problem is the tutorials i get they always in imperial units which we do not use here.Therefore i am looking for a residential template which can work nice in Southern Africa with metric units. Thanks Sent from my iPhone using Tapatalk Pro Quote
halam Posted November 2, 2016 Posted November 2, 2016 With the change of making a very stupid Revi'doo.. question...what if you change the units in the manage/ options tab?? Quote
tzframpton Posted November 2, 2016 Posted November 2, 2016 With the change of making a very stupid Revi'doo.. question...what if you change the units in the manage/ options tab??This is precisely what needs to be done. Simply type UN and change the Units to Metric. Revit auto-adjusts everything, unlike AutoCAD. -TZ Quote
Tawez Posted November 2, 2016 Author Posted November 2, 2016 Thank you tzframpton Does it also change the dimensions of families aswel automatically. Sent from my iPhone using Tapatalk Pro Quote
tzframpton Posted November 2, 2016 Posted November 2, 2016 Thank you tzframpton Does it also change the dimensions of families aswel automatically. Sent from my iPhone using Tapatalk Pro Everything should reset without any problems, including Families. I believe Revit was built to handle this task very effectively. -TZ Quote
