benhubel Posted October 26, 2016 Posted October 26, 2016 I am writing a routine that requires that I remove objects from a selection set while still keeping the original set around. After running into issues, I created a test routine to see how ssdel is operating. I want it to remove selB from selC, while keeping selA and selD untouched to hold the original selection. It is removing selB from all related selection sets though. Why is it doing this, and how can I fix it? (defun c:TD () ;Test Delete (setq selA(ssget)) ;get base selection A (setq selB(ssget)) ;get selection B to remove from selection C (setq selC selA) ;copies selection A and removes selection B to return the difference (setq selD selA) ;extra variable to test how ssdel works (setq i 0) ;index (repeat (sslength selB) ;repeat for each entity in selB (ssdel (ssname selB i) selC) ;intended to remove selB from selC. It is also removeing selB from selA, which I don't want. (setq i (1+ i))) ;increment ) ;Functions below are used to test which geometry is contained in which selection set (defun c:dela () ;delete geometry in selection A (If(/= nil selA)(command ".erase" selA "")(princ "\n selA is empty. Run TD to initialize"))(princ)) ;if selA contains entities, delete them. If not, display error. (defun c:delb () ;delete geometry in selection B (If(/= nil selB)(command ".erase" selB "")(princ "\n selB is empty. Run TD to initialize"))(princ)) ;if selB contains entities, delete them. If not, display error. (defun c:delc () ;delete geometry in selection C (If(/= nil selC)(command ".erase" selC "")(princ "\n selC is empty. Run TD to initialize"))(princ)) ;if selC contains entities, delete them. If not, display error. (defun c:deld () ;delete geometry in selection d (If(/= nil selD)(command ".erase" selD "")(princ "\n selD is empty. Run TD to initialize"))(princ)) ;if selD contains entities, delete them. If not, display error. Quote
David Bethel Posted October 26, 2016 Posted October 26, 2016 This does not copy the PICKSET, (setq selC selA) It simply makes another pointer to the original selection set Command: sq Variable Name: ss1 Variable Value: (ssget) Select objects: Other corner: 3 found Select objects: <Selection set: 701> Command: sq Variable Name: ss2 Variable Value: (ssget) Select objects: c First corner: Other corner: 2 found Select objects: c First corner: Other corner: 1 found Select objects: <Selection set: 702> Command: (setq ss3 ss1) <Selection set: 701> Command: (sslength ss3) 3 Command: (ssdel (ssname ss1 0) ss3) <Selection set: 701> Command: (sslength ss1) 2 Command: !SS3 <Selection set: 701> Command: !SS1 <Selection set: 701> See how everything refers back to selection set 701 in this example -David Quote
benhubel Posted October 26, 2016 Author Posted October 26, 2016 Thank you! I'm going to do research on the matter. If you have suggestions on how to modify the routine to work how I want, that would rock, but I think I now have enough information to search out the answer. I greatly appreciate how quickly you answered. Thanks Quote
David Bethel Posted October 26, 2016 Posted October 26, 2016 To copy a a PICKESET : (defun css (ss / rs i en) (setq rs (ssadd) (setq i 0) (while (setq en (ssname ss i)) (ssadd en rs) (setq i (1+i))) rs) (setq ss2 (css ss1)) Written on the fly - Untested -David Quote
marko_ribar Posted October 26, 2016 Posted October 26, 2016 You can do it even with less coding... Only you must have Express Tools installed : (setq ss2 (acet-ss-union (list ss1))) Quote
benhubel Posted October 26, 2016 Author Posted October 26, 2016 (edited) Thank you both! It was taking longer to figure out than I expected. It's working perfectly now. I'm also glad to have both versions, as I can now use it in a wider variety of routines. I do have Express Tools installed, so I'm good there. For future reference of anybody who might want it, the final solution implemented in my code is as follows: (defun c:TD () ;Test Delete (setq selA (ssget)) ;get base selection A (setq selB (ssget)) ;get selection B to remove from selection C (setq selC (acet-ss-union (list selA))) ;creates a new selection set and copies selection A (setq i 0) ;index (repeat (sslength selB) ;repeat for each entity in selB (ssdel (ssname selB i) selC) ;removes selB from selC (setq i (1+ i))) ;increment ) ;Functions below are used to test which geometry is contained in which selection set (defun c:dela () ;delete geometry in selection A (If(/= nil selA)(command ".erase" selA "")(princ "\n selA is empty. Run TD to initialize"))(princ)) ;if selA contains entities, delete them. If not, display error. (defun c:delb () ;delete geometry in selection B (If(/= nil selB)(command ".erase" selB "")(princ "\n selB is empty. Run TD to initialize"))(princ)) ;if selB contains entities, delete them. If not, display error. (defun c:delc () ;delete geometry in selection C (If(/= nil selC)(command ".erase" selC "")(princ "\n selC is empty. Run TD to initialize"))(princ)) ;if selC contains entities, delete them. If not, display error. Edited October 26, 2016 by benhubel Corrected a comment in the code Quote
