Hello, guys!
I need a lisp to rename the current open file. I already have a routine that takes the current file name and creates a string with the new file name (Just six numbers in the old name needs to change)... But I coudn't change the old name for the new name. I've tried to use the (Vl-File-Rename), but I think that i didn't use it right.... Here's go the code:
(defun C:changename (n1 n2 n3 n4 n5 n6)
(setq new_number (strcat (itoa n1)
(itoa n2)
(itoa n3)
(itoa n4)
(itoa n5)
(itoa n6)))
(setq old_name (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")))
(setq size (strlen old_name))
(setq final (- size 18 )) ;
(setq start_name (substr old_name 1 final ))
(setq end_name (substr old_name (+ final 7) (- size final)))
(setq new_name (strcat start_name new_number end_name))
(alert old_name)
(alert new_name)
(vl-file-rename old_name new_name)
); end defun
The old name is: D:\Profiles\s-Andre.Almeida\Desktop\Autocad\3-157941-012-005.dwg
The new name, for example, could be: D:\Profiles\s-Andre.Almeida\Desktop\Autocad\3-666666-012-005.dwg
I just need to change the names with the (vl-file-rename)
could someone help me?
Edited by andr3flaviano
I doubt you can rename a file while it is open. Why not choose instead to do a "saveas" under a new file name?
Here :
(- size final) is sufficient... You could just use :
(setq end_name (substr old_name (+ final 7)))
Hmmmmm...
I thought that i could rename the opened file, but i will use the "Save as" so... Thank you, guys!
