donovanc80 Posted October 17, 2016 Share Posted October 17, 2016 Hi Guys. Is there any way to set maximum incline/decline parameters when creating a best fit vertical road profile? Quote Link to comment Share on other sites More sharing options...
MillerMG Posted October 20, 2016 Share Posted October 20, 2016 This may or may not help you out. I am hoping for the 'may'. This is what I was able to find about Best Fit Profile information: The command attempts to run a complex algorithm to determine the best fit profile, including both tangents and vertical curves. However, the only best fit option available for determining vertical curves is the maximum cure radius. The maximum curve radius does not apply in a design that uses parabolic curves, the most common curves found in roadway design. Once the analysis is run, a Best Fit Report is provided; however, unlike the Best Fit command for lines and curves, this command has no options for selecting or deselecting points. Quote Link to comment Share on other sites More sharing options...
