jkoll66 Posted October 13, 2016 Posted October 13, 2016 Hi all, I have been tasked with coming up with a dynamic block that is for a chute. It is a simple rectangle that I've added some attributes to and a field within one of the attributes. What I need the formula to do is calculate the angle of the chute based on user input for the upper height and the lower height (rise) and "Distance 1" (run) and then return the answer in the field. It returns the correct angle on insertion, however, when I change any of the values and Regen the result is incorrect. In addition, I would like the "Angle" attribute to not show in the dialog box when inserted. Is that possible? Thanks. Chute plan view.dwgFetching info... Quote
Ski_Me Posted October 13, 2016 Posted October 13, 2016 Ok so what formula are you using because your trying to find an angle using x and y coordinates. This would be a trigonometric function which you can't do with a formula in AutoCAD. If you look at the formulas you can use they are limited to average, sum, count, and cell. Just the basic add, subtract, multiply, and divide. If look at the Auto Desk Exchange there is a app you can get that will give you those features to do SIN COS and TAN but you have to pay for it and it's not cheap. What you could do is find the cos by dividing the y value by the hypotenuse which is just simple math then you could use the law of cosines to solve for the angle. it will take a lot of work but doable I think. You might be better off looking into using a lookup instead of a attribute. Quote
jkoll66 Posted October 14, 2016 Author Posted October 14, 2016 I was finally able to get it to work. Not sure what I did to correct the issue. I just started over from scratch. It looks the same as what I had. I may have selected "none" this time for units in the formula. Anyway, AutoCAD can do formulas. I found this site that lists arithmetic functions that can be used with AutoCAD http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6381. Attached is the working block. Thanks Chute plan view.dwgFetching info... Quote
Ski_Me Posted October 14, 2016 Posted October 14, 2016 I cant get it to work what am I doing wrong. I didn't realize AutoCAD supported all those other functions. Kinda nice to know. Quote
jkoll66 Posted October 14, 2016 Author Posted October 14, 2016 Did you "Regen" after changing the values or stretching? Also, make sure your units are inches and that you are in "Architectural" mode. Quote
Ski_Me Posted October 14, 2016 Posted October 14, 2016 Ok I got it to work. I was thinking that the angle was wrong but then remembered it's rise over distance that defines the angle not the distance of the rise if that makes sense. It took a few tries to get it to work but I works like you said. Quote
jkoll66 Posted October 14, 2016 Author Posted October 14, 2016 Good, I'm glad you got it to work. I was starting to worry I still had something wrong! Quote
