pvsvprasad Posted October 4, 2016 Posted October 4, 2016 Dear Masters, what is the wrong in my lisp program.please find error message while using the code. kindly fix the error. ;___________________________________________________________________________________________________________ ; ; Function to export a the coordinates of a group of points to excel (using csv file method) ;___________________________________________________________________________________________________________ (defun C:MirrorPoints (/ lstOfPoints lstSelections ssSelections strCSVFullName) (if (and (setq ssSelections (ssget "x" (list (cons 0 "POINT")))) (setq lstSelections (selectionsettolist ssSelections)) (setq lstOfPoints (mapcar '(lambda (X)(vlax-get X "coordinates")) lstSelections)) (setq lstOfPoints (mapcar (quote (lambda (X)(mapcar '* (list 1 -1 1) X))) lstOfPoints));<- Mirrored about X-X (setq lstOfPoints (mapcar (quote (lambda (X)(mapcar '+ (list 0 3000 0) X))) lstOfPoints));<- add 3000 to Y coordinate (setq lstOfPoints (cons (list "X" "Y" "Z") lstOfPoints)) (setq strCSVFullName (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv")) ) (progn (while (vl-string-search " " strCSVFullName)(setq strCSVFullName (vl-string-subst "" " " strCSVFullName))) ;Startapp doesn't like spaces (ListToCSVFile strCSVFullName lstOfPoints ",") (startapp "C:\\Program Files (x86)\\Microsoft Office\\Office12\\EXCEL.EXE" strCSVFullName) ) ) ) ;___________________________________________________________________________________________________________ ; ; Function to convert a entity based selection set to a list. ;___________________________________________________________________________________________________________ (defun SelectionSetToList (ssSelections / entSelection intCount lstObjects objSelection ) (repeat (setq intCount (sslength ssSelections)) (setq intCount (1- intCount)) (setq entSelection (ssname ssSelections intCount)) (setq objSelection (vlax-ename->vla-object entSelection)) (setq lstObjects (cons objSelection lstObjects)) ) (reverse lstObjects) ) ;___________________________________________________________________________________________________________ ; ; Export a list of sublists of to a text file ;___________________________________________________________________________________________________________ (defun ListToCSVFile (strFilename lstOfSublists strChar / strText strText2 filData lstSublist) (setq filData (open strFileName "w")) (close filData) (setq filData (open strFileName "w")) (foreach lstSubList lstOfSublists (setq strText (vl-princ-to-string (nth 0 lstSubList))) (if (and (= (type (cdr lstSublist)) 'LIST) (> (length lstSublist) 1) ) (foreach strText2 (cdr lstSubList) (setq strText (strcat strText strChar (vl-princ-to-string strText2))) ) (if (cdr lstSublist) (setq strText (strcat strText strChar (vl-princ-to-string (cdr lstSubList)))) ) ) (write-line strText filData) ) (close filData) (prin1) ) (vl-load-com) Thank you, with best regards. Quote
Lee Mac Posted October 4, 2016 Posted October 4, 2016 Remove: (while (vl-string-search " " strCSVFullName)(setq strCSVFullName (vl-string-subst "" " " strCSVFullName))) And change: (startapp "C:\\Program Files (x86)\\Microsoft Office\\Office12\\EXCEL.EXE" strCSVFullName) to: (startapp "C:\\Program Files (x86)\\Microsoft Office\\Office12\\EXCEL.EXE" (strcat "\"" strCSVFullName "\"")) Quote
pvsvprasad Posted October 5, 2016 Author Posted October 5, 2016 Lee Mac said: Dear sir, Thank you for fixing error. Best Wishes. Quote
pvsvprasad Posted March 11, 2017 Author Posted March 11, 2017 Lee Mac said: You're welcome! Hello sir, After long time i have tried your modified code. i have face some technical issues by excel output. actually i need mirror points to excel. but at excel showing un natural values. please find sample format of excel out image. kindly fix the error. Best wishes. Mirror points export required.dwgFetching info... Quote
