Offset without offsetgaptype, leaving the corners opened.
Hi Everybody,
I'm looking for a way to offset a polyline without changing the lenght of the segments.
I looked into offsetgaptype, but the option to not close the gap isn't one of them.
Below is an example of what I want, the pink segments should be removed:
I don't mind writing some code myself, but I have no idea how to offset the segments separately or how to figure out which side was chosen.
Any help is greatly appreciated.
Quick and dirty example...
(defun c:OAS (/ dst ent pnt obj p1 p2 lst)
 ;; http://www.cadtutor.net/forum/showthread.php?98338-Offset-without-offsetgaptype-leaving-the-corners-opened.
 (initget 6)
 (if (and (setq dst (getdist "\nSpecify offset distance: "))
          (setq ent (car (AT:GetSel entsel
                                    "\nSelect LWPolyline to offset all segments without connecting: "
                                    (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "LWPOLYLINE"))
          (setq pnt (getpoint "\nSpecify point on side to offset: "))
          (setq obj (vlax-ename->vla-object ent)
                pnt (trans pnt 1 0)
                p1  (vlax-curve-getclosestpointtoprojection ent pnt '(0 0 1))
          (setq p2 (cond
                     ((vlax-curve-getPointAtDist ent (+ (vlax-curve-getDistAtPoint ent p1) 0.00001)))
                     ((vlax-curve-getPointAtDist ent (- (vlax-curve-getDistAtPoint ent p1) 0.00001)))
          (setq dst (if (minusp (- (* (- (car p2) (car p1)) (- (cadr pnt) (cadr p1)))
                                   (* (- (cadr p2) (cadr p1)) (- (car pnt) (car p1)))
                      (- dst)
                      dst
          (setq lst (vlax-invoke (vlax-ename->vla-object ent) 'Explode))
   (foreach o lst
     (vla-offset
       o
       (if (and (eq (vla-get-objectname o) "AcDbArc")
                (> (vla-get-startangle o) pi)
         (- dst)
         dst
     (vla-delete o)
(defun AT:GetSel (meth msg fnc / ent)
 ;; meth - selection method (entsel, nentsel, nentselp)
 ;; msg - message to display (nil for default)
 ;; fnc - optional function to apply to selected object
 ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
 ;; Alan J. Thompson, 05.25.10
 (while
   (progn (setvar 'ERRNO 0)
          (setq ent (meth (cond (msg)
                                ("\nSelect object: ")
          (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
                ((eq (type (car ent)) 'ENAME)
                 (if (and fnc (not (fnc ent)))
                   (princ "\nInvalid object!")
 ent
Wow, that works really well. Thanks!
I understand what happens with the exploding and the loop offsetting all the items,
but how does it know which side to offset?
Just for anyone else who is interested, I changed the code so it gets the last used offset distance from the default offset command (and changes it) and it now offsets to the current layer:
(defun c:OAS (/ dst ent pnt obj p1 p2 lst clayer)
   (initget 6)
   [color=red](setq clayer (getvar "clayer"))[/color]
   (if (and
      [color=red](if (setq dst (getdist (strcat "\nSpecify Offset Distance or <" (rtos (abs (getvar 'Offsetdist)) 2 4) ">: ")))
             (setvar 'Offsetdist dst)
             (setq dst (abs (getvar 'Offsetdist)))
          )[/color]
          (setq ent (car (AT:getsel entsel "\nSelect LWPolyline to offset all segments without connecting: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "LWPOLYLINE")))))
                pnt (trans pnt 1 0)
          (setq p2 (cond
                      (- dst)
                      dst
   (foreach o lst
     (vla-offset
       o
         (- dst)
         dst
     [color=red](vla-put-layer (vlax-EName->vla-Object (entlast)) clayer)[/color]
     (vla-delete o)
(defun AT:getsel (meth msg fnc / ent)
 (while
 ent
See noted code.
(setq pnt (getpoint "\nSpecify point on side to offset: ")) ; pick point on side to offset
     pnt (trans pnt 1 0)
     p1  (vlax-curve-getclosestpointtoprojection ent pnt '(0 0 1)) ; get point on polyline closest to picked point 'pnt'
(setq p2 (cond
          ((vlax-curve-getPointAtDist ent (+ (vlax-curve-getDistAtPoint ent p1) 0.00001))) ; create 2nd point 0.00001 to left or right
          ((vlax-curve-getPointAtDist ent (- (vlax-curve-getDistAtPoint ent p1) 0.00001))) ; depending on what it can create
(setq dst (if (minusp (- (* (- (car p2) (car p1)) (- (cadr pnt) (cadr p1))) ; area of triangle will return
                        (* (- (cadr p2) (cadr p1)) (- (car pnt) (car p1))) ; negative/positive number depending on direction
           (- dst) ; change vla-offset distance + or - depending on direction
           dst
Mod on your mod...
(defun c:OAS (/ dst ent pnt cla obj p1 p2 lst)
 (initget 6 "Through")
 (setq dst (getdist (strcat "\nOffset Nested\nSpecify offset distance or [Through] <"
                            (if (minusp (getvar 'OFFSETDIST))
                              "Through"
                              (rtos (getvar 'OFFSETDIST))
 (cond ((not dst))
       ((eq (getvar 'OFFSETDIST) dst))
       ((eq dst "Through") (setvar 'OFFSETDIST -1.))
       ((setvar 'OFFSETDIST dst))
 (if (and (setq ent (AT:GetSel entsel
          (setq pnt (getpoint (cadr ent)
                                "\nSpecify through point: "
          (setq ent (car ent)
                cla (getvar 'CLAYER)
                pnt (trans pnt 1 0)
          (setq p2 (cond
          (setq dst (if (minusp (getvar 'OFFSETDIST))
                      (distance (list (car p1) (cadr p1)) (list (car pnt) (cadr pnt)))
                      dst
                      (- dst)
                      dst
   (foreach o lst
     (vla-put-layer o cla)
     (vla-offset
       o
         (- dst)
         dst
     (vla-delete o)
(vl-load-com)
 (while
 ent
