Hi,
I come back after long time.
I feel like new here.
Please can someone tell me how to make icon size larger in 3DS MAX 2016 ?
Thank you
I don't think you can make them larger.
If you open your Preferences window, (Customize menu > Preferences), go to the "General" tab > "UI Display" you can choose to "Use Large Toolbar Buttons", but I believe that is the standard default, so your buttons should already be full size.
  • 2 months later...
1- Click "Customize"
2- "Preferences"
3- "Use Large Toolbar Buttons
4- Restart 3ds Max to see your new icon size
If "Use Large Toolbar Buttons" is checked then you already are using the largest icon size possible
Adsk
  BEKA said:
Hi,
Thank you
By chance are you using a 4k monitor? I have seen many people complain about interface/icon support for these in native resolution. I believe Autodesk has an update for the latest versions of their software to support this.
-TZ
