boxel0 Posted September 21, 2016 Posted September 21, 2016 Any lisps out there, which could speed this up? How to trim lines quicker than this, its company / industry standard to break all vertical lines, which pass through a horizontal line by 3 above and below I spend my whole life doing this Quote
ReMark Posted September 21, 2016 Posted September 21, 2016 A simple search using the following criteria "autocad"+"break vertical lines"+"lisp" is all it took to find this gem. With a minor tweak or two it could be edited to eliminate the jump block or substitute a different block of the user's choice. http://cadtips.cadalyst.com/linear-objects/dynamically-break-crossing-lines Other lisp routines discussed in this thread... http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/break-lines-horizontally-or-vertically/td-p/3922610 Quote
