ILoveMadoka Posted September 21, 2016 Share Posted September 21, 2016 (Autocad 2015) Express Tools is loaded, the Express Tools menu is displayed. 97% or more of the Express Tools work just fine. Tools -> System Variables (SYSVDLG) does not work (Unknown Command) Is there a way to manually fix this short of the uninstall/reinstall? Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted September 21, 2016 Author Share Posted September 21, 2016 (edited) This IS the fix (worked for me anyway) Run ARX (type ARX at the command line) Pick Load Navigate to the Express Folder Pick SYSVDLG.arx Ref: https://forums.autodesk.com/t5/autocad-express-tools/sysvdlg/td-p/363561 Edited September 22, 2016 by ILoveMadoka Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 21, 2016 Share Posted September 21, 2016 Uninstalling then reinstalling should be the option of LAST resort. Would you run out and buy four brand new tires for your car if just one was low on air? Quote Link to comment Share on other sites More sharing options...
rkent Posted September 21, 2016 Share Posted September 21, 2016 Try each of these, testing after each one to see if it has fixed it. Close and restart AutoCAD. Close and restart Windows. Check DEMANDLOAD and set to 3 if it is not. Log into Windows under another profile and check to see if it works. If you have another computer there where everything is working then compare the Support File Search Path. Options, Files, ... Make changes to your computer if found to be missing somethings. Quote Link to comment Share on other sites More sharing options...
f700es Posted September 22, 2016 Share Posted September 22, 2016 Uninstalling then reinstalling should be the option of LAST resort. Would you run out and buy four brand new tires for your car if just one was low on air? Sorry ReMark poor analogy. One option is free and relatively quick. The other is not free nor quick or even related. Hate to bust your chops on this but well Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted September 22, 2016 Author Share Posted September 22, 2016 (edited) I only mentioned the uninstall/reinstall because it was the only solution anyone posted on one post that I found. I posted the steps I used to get it to work. (see above..) It was an .arx file that the Express Tools does/did not load automatically for some reason. Manually loaded and worked fine... See my second post above... Edited September 22, 2016 by ILoveMadoka Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted September 22, 2016 Author Share Posted September 22, 2016 ReMark... I'm an old fart.... Uninstall/reinstall is ALWAYS the LAST option... And even then I don't want to do it! Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 22, 2016 Share Posted September 22, 2016 For too many people it is the FIRST option unfortunately. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted September 22, 2016 Author Share Posted September 22, 2016 My problem is I'll dink around for an hour or two with a problem before I come to my senses and see what Google has to say... Youtube is usually stop No. 2... Quote Link to comment Share on other sites More sharing options...
f700es Posted September 22, 2016 Share Posted September 22, 2016 Nothing wrong with "dinking around" and trying yourself Quote Link to comment Share on other sites More sharing options...
MillerMG Posted September 23, 2016 Share Posted September 23, 2016 Sorry ReMark poor analogy. One option is free and relatively quick. The other is not free nor quick or even related. Hate to bust your chops on this but well the analogy was comical that's for sure. Quote Link to comment Share on other sites More sharing options...
