Draw a line and Offset LISP
heng7653
(defun c:Test (/ pt1 pt2 pt3 ang)
 ;; Tharwat - 04.Jun.2016	;;
 (or *offdist* (setq *offdist* 0.1))
 (initget 6)
 (if (setq *offdist*
            (cond ((getdist (strcat "\nSpecify *offdist*set distance "
                                    (strcat "< " (rtos *offdist* 2 2) " > :")
                  (*offdist*)
   (while (and (setq pt1 (getpoint "\n1st point :"))
               (setq pt2 (getpoint "\n2nd point :" pt1))
               (setq pt3 (getpoint "\nSpecify offset side :"))
               (setq ang (angle pt1 pt2))
     (setq ang ((if (minusp (sin (- ang (angle pt2 pt3))))
                 ang
                 (* pi 0.5)
     (entmakex
       (list '(0 . "LINE")
             (cons 10 (trans (polar pt1 ang *offdist*) 1 0))
             (cons 11 (trans (polar pt2 ang *offdist*) 1 0))
  • 4 years later...
 (initget 6)
 (if (setq *offdist*
                  (*offdist*)
                 ang
                 (* pi 0.5)
     (entmakex
       (list '(0 . "LINE")
Can you add what it will look like and on which side it will be before you draw the line?
Like the offset command.
That's what it does currently but after specifying the two points that represents the assumed line
I am using Autocad 2022 version but As you said, after selecting 2 points, it doesn't show me a sampling of which side it will be on. I tried to add gif but failed. That's why I uploaded it as a link.
https://imgur.com/a/eBCBEGy
You can add the grdraw function to create a rubber band for a better review before specifying the side point like this:
(not (grdraw pt1 pt2 2)) ;; this expression
Thanks but I wanted to see the newly drawn line. Can you show me the sampling as if the pt3 point was selected without the pt3 point selected? This way i can see if it is in the range i want. Then I can choose pt3 and finish the process.
Edited by Scoutr4
I'm editing the post because for the first time I was a newbie to explain my problem.
