Hi
i need a LISP for draw a line(2 point), offset it(erase source) and then repeat again draw line and offset until i press Esc for end this command. Ask for offset distance before i draw a line for one time only. Thanks for your help..
Hi,
Try this program and just hit ENTER if you want to end the program.
(defun c:test (/ off pt1 pt2 ent vla)
 ;; Tharwat - 17.Sep.2016	;;
 (cond
   ((= 4
       (logand
         4
         (cdr
           (assoc 70 (entget (tblobjname "LAYER" (getvar 'clayer)))))))
    (alert "Current layer is Locked <!>"))
   ((setq off (getdist "\nSpecify offset distance :"))
    (while (and (setq pt1 (getpoint "\n1st point :"))
                (setq pt2 (getpoint "\n2nd point :" pt1))
                (setq ent (entmakex (list '(0 . "LINE")
                                          (cons 10 (trans pt1 1 0))
                                          (cons 11 (trans pt2 1 0)))))
                (setq vla (vlax-ename->vla-object ent))
      (mapcar '(lambda (d) (vla-offset vla d)) (list off (- off)))
      (entdel ent)
 )(vl-load-com)
Heres my practice/attempt (didn't fully understood what should've be the result from the offset):
[b][color=BLACK]([/color][/b]defun C:test [b][color=FUCHSIA]([/color][/b] / acDoc uFlag SysVars *error* d p pl pn OFFpoly [b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]setq uFlag [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]vla-StartUndoMark [b][color=GREEN]([/color][/b]setq acDoc [b][color=BLUE]([/color][/b]vla-get-ActiveDocument [b][color=RED]([/color][/b]vlax-get-acad-object[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[color=#8b4513]; [b][color=FUCHSIA]([/color][/b]vlax-invoke [b][color=NAVY]([/color][/b]or acDoc [b][color=MAROON]([/color][/b]setq acDoc [b][color=GREEN]([/color][/b]vla-get-ActiveDocument [b][color=BLUE]([/color][/b]vlax-get-acad-object[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] 'StartUndoMark[b][color=FUCHSIA])[/color][/b][/color]
[b][color=FUCHSIA]([/color][/b]setq SysVars [b][color=NAVY]([/color][/b]mapcar '[b][color=MAROON]([/color][/b]lambda [b][color=GREEN]([/color][/b]x[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list x [b][color=BLUE]([/color][/b]getvar x[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] '[b][color=MAROON]([/color][/b][color=#2f4f4f]"CMDECHO"[/color] [color=#2f4f4f]"CLIPROMPTLINES"[/color] [color=#2f4f4f]"NOMUTT"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]mapcar '[b][color=NAVY]([/color][/b]lambda [b][color=MAROON]([/color][/b]n v[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setvar n v[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]mapcar 'car SysVars[b][color=NAVY])[/color][/b] '[b][color=NAVY]([/color][/b]0 2 0[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]defun stringp [b][color=NAVY]([/color][/b] x / [b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]= [b][color=GREEN]([/color][/b]type x[b][color=GREEN])[/color][/b] 'STR[b][color=MAROON])[/color][/b] 'T nil[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]defun *error* [b][color=NAVY]([/color][/b] msg [b][color=NAVY])[/color][/b]
	[b][color=NAVY]([/color][/b]and uFlag [b][color=MAROON]([/color][/b]vla-EndUndoMark acDoc[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
	[color=#8b4513]; [b][color=NAVY]([/color][/b]and acDoc [b][color=MAROON]([/color][/b]vlax-invoke acDoc 'EndUndoMark[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][/color]
	[b][color=NAVY]([/color][/b]if SysVars [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]x[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setvar [b][color=RED]([/color][/b]car x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cadr x[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] SysVars[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
	[b][color=NAVY]([/color][/b]if OFFpoly [b][color=MAROON]([/color][/b]entdel OFFpoly[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
		[b][color=MAROON]([/color][/b]or
			[b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]member msg '[b][color=RED]([/color][/b][color=#2f4f4f]"Function cancelled"[/color] [color=#2f4f4f]"quit / exit abort"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]wcmatch [b][color=BLUE]([/color][/b]strcase msg[b][color=BLUE])[/color][/b] [color=#2f4f4f]"*BREAK,*CANCEL*,*EXIT*"[/color][b][color=GREEN])[/color][/b]
		[b][color=MAROON]([/color][/b]princ [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\nError: "[/color] msg[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
	[b][color=NAVY]([/color][/b]princ[b][color=NAVY])[/color][/b]
[b][color=FUCHSIA]([/color][/b]if
	[b][color=NAVY]([/color][/b]setq
		d [b][color=MAROON]([/color][/b]getreal [color=#2f4f4f]"\nSpecify offset distance: "[/color][b][color=MAROON])[/color][/b]
		p [b][color=MAROON]([/color][/b]getpoint [color=#2f4f4f]"\nSpecify first point for the line: "[/color][b][color=MAROON])[/color][/b]
		pl [b][color=MAROON]([/color][/b]list p[b][color=MAROON])[/color][/b]
	[b][color=NAVY]([/color][/b]progn
		[b][color=MAROON]([/color][/b]setvar 'errno 0[b][color=MAROON])[/color][/b]
		[b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]/= [b][color=BLUE]([/color][/b]getvar 'errno[b][color=BLUE])[/color][/b] 52[b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]initget 128 [color=#2f4f4f]"Done Exit"[/color][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]if pn
				[b][color=BLUE]([/color][/b]setq pn [b][color=RED]([/color][/b]getpoint pn [color=#2f4f4f]"\nSpecify next point or [Done/Exit]: "[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
				[b][color=BLUE]([/color][/b]setq pn [b][color=RED]([/color][/b]getpoint p [color=#2f4f4f]"\nSpecify next point: "[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
			[b][color=GREEN]([/color][/b]cond
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]or [b][color=PURPLE]([/color][/b]= pn [color=#2f4f4f]""[/color][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]not pn[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]null pn[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]setq pn pn[b][color=RED])[/color][/b]
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]and [b][color=PURPLE]([/color][/b]not [b][color=TEAL]([/color][/b]stringp pn[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]/= pn [color=#2f4f4f]""[/color][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]listp pn[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]setq pl [b][color=PURPLE]([/color][/b]append pl [b][color=TEAL]([/color][/b]list pn[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]if OFFpoly [b][color=PURPLE]([/color][/b]entdel OFFpoly[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]LWPoly pl 0[b][color=PURPLE])[/color][/b]
						[b][color=PURPLE]([/color][/b]progn
							[b][color=TEAL]([/color][/b]vl-cmdf [color=#2f4f4f]"_.OFFSET"[/color] [color=#2f4f4f]"_Erase"[/color] [color=#2f4f4f]"_Y"[/color] d [b][color=OLIVE]([/color][/b]entlast[b][color=OLIVE])[/color][/b] d [color=#2f4f4f]""[/color][b][color=TEAL])[/color][/b]
							[b][color=TEAL]([/color][/b]setq OFFpoly [b][color=OLIVE]([/color][/b]entlast[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b]
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]and [b][color=PURPLE]([/color][/b]stringp pn[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]/= pn [color=#2f4f4f]""[/color][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]wcmatch pn [color=#2f4f4f]"D*"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]if OFFpoly [b][color=PURPLE]([/color][/b]vl-cmdf [color=#2f4f4f]"_.EXPLODE"[/color] OFFpoly[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]setvar 'errno 52[b][color=RED])[/color][/b]
				[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]and [b][color=PURPLE]([/color][/b]stringp pn[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]wcmatch pn [color=#2f4f4f]"E*"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
					[b][color=RED]([/color][/b]princ [color=#2f4f4f]"\nExiting! "[/color][b][color=RED])[/color][/b]
				[b][color=BLUE]([/color][/b]T
					nil
			[b][color=GREEN])[/color][/b][color=#8b4513]; cond[/color]
		[b][color=MAROON])[/color][/b][color=#8b4513]; while[/color]
	[b][color=NAVY])[/color][/b][color=#8b4513]; progn[/color]
[b][color=FUCHSIA])[/color][/b][color=#8b4513]; if[/color]
[b][color=FUCHSIA]([/color][/b]mapcar '[b][color=NAVY]([/color][/b]lambda [b][color=MAROON]([/color][/b]x[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setvar [b][color=GREEN]([/color][/b]car x[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cadr x[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] SysVars[b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]setq uFlag [b][color=NAVY]([/color][/b]vla-EndUndoMark acDoc[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[color=#8b4513]; [b][color=FUCHSIA]([/color][/b]vlax-invoke acDoc 'EndUndoMark[b][color=FUCHSIA])[/color][/b][/color]
[b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b]
[b][color=BLACK])[/color][/b][color=#8b4513];| defun |; [b][color=BLACK]([/color][/b]vl-load-com[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]princ[b][color=BLACK])[/color][/b][/color]
[color=#8b4513]; © Lee Mac[/color]
[b][color=BLACK]([/color][/b]defun LWPoly [b][color=FUCHSIA]([/color][/b]lst cls[b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]entmakex
	[b][color=NAVY]([/color][/b]append
			[b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"LWPOLYLINE"[/color][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]cons 100 [color=#2f4f4f]"AcDbEntity"[/color][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]cons 100 [color=#2f4f4f]"AcDbPolyline"[/color][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]cons 90 [b][color=BLUE]([/color][/b]length lst[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
			[b][color=GREEN]([/color][/b]cons 70 cls[b][color=GREEN])[/color][/b]
		[b][color=MAROON]([/color][/b]mapcar [b][color=GREEN]([/color][/b]function [b][color=BLUE]([/color][/b]lambda [b][color=RED]([/color][/b]p[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 10 p[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] lst[b][color=MAROON])[/color][/b]
@Grrr, copy and paste the following codes into you Vlide Console and when codes ask you for values just hit ENTER:
(if (setq		d (getreal "\nSpecify offset distance: ")
		p (getpoint "\nSpecify first point for the line: ")
		pl (list p)
(alert "passed ..."))
After that check the value for each variable (d p pl).
What will you find out?
		pl (list p)
It added the nil symbol to the 'pl' list, and evaluated the if expression as T... so I should've wrote it like this:
(if
(setq
	(setq pl (list p))
Thank you for the catch...
Unfortunately I have alot free time to write codes and read the forums, but I don't have ACAD on that PC I'm working, so no debugging nor consoles. :(
Atleast I'm happy that you are helping and I really appreciate it!
That should work for the last expression ONLY.
As in your example, hit enter for the first input and after that specify a point when codes ask for that, then you'd have the same result as if you are entering values for the two inputs. ;)
eg:
(if
(setq
	d (getreal "\nSpecify offset distance: ")           [color="red"];; Hit enter for this expression [/color]
	p (getpoint "\nSpecify first point for the line: ") [color="blue"];; specify a point[/color]
	(setq pl (list p))
	(alert "passed ...") [color="magenta"];; this should be altered for sure although variable 'd' is equal to NIL [/color]
Damn... I thought I did something clever by skipping some (and) function, but you proved me wrong, thanks once again! :)
You are welcome.
As a conclusion: Just be aware when you add more than one expression with setq, only the last expression would return the value.
I am just trying to help here and not trying to pick up mistakes - Happy coding.:)
Hi @Tharwat
Thanks for the reply and help. this is what i want, but i need one side offset only (maybe i have to click mouse for offset direction). How to modify the LISP? Thank you very much.
Edited by heng7653
A simple method for single line using code above.
;(mapcar '(lambda (d) (vla-offset vla d)) (list off (- off))) ; two lines
(vla-offset vla off) ; one side only note  -ve off value will go to right +ve to left
@BIGAL, I think I know how to modify MY codes so if you have any COMPLETE codes just post them to OP and please don't modify mine in that way.
@tharwat
not fix which side because not same side every time, so hope can select side as usual offset like normal, just no need to select object.
@tharwat
Try this:
(defun c:test (/ off pt1 pt2 pt3 ang)
 ;; Tharwat - 20.Sep.2016	;;
 (if (setq off (getdist "\nSpecify offset distance :"))
               (setq pt3 (getpoint "\nSpecify offset side :"))
               (setq ang (angle pt1 pt2))
     (setq ang (if (minusp (sin (- ang (angle pt2 pt3))))
                 (+ ang (* pi 0.5))
                 (- ang (* pi 0.5))
                     (cons 10 (trans (polar pt1 ang off) 1 0))
                     (cons 11 (trans (polar pt2 ang off) 1 0)))))
Try this:
                 (+ ang (* pi 0.5))
                 (- ang (* pi 0.5))
Consider adding the following line of code before prompting for offset side point.
(not (grdraw (getpoint) (getpoint) 7 -1))
I agree with you if we have more than two points to pick but in this case there are only two points and that is already handled by the getpoint function.
Nice to see you contributing again Alanjt.
You are picking more than two points.
You pick the two points to draw the line, then you are blindly picking a third point for the offsetting side.
grdraw'ing the line before picking the offset side would remove the blind point selection.
Nice to be seen. I'll pop in from time-to-time.
  • 1 year later...
hi
anyone know how to edit this code? as I want it show previous offset distance every time command start.
(defun c:aa (/ off pt1 pt2 pt3 ang)
                 (+ ang (* pi 0.5))
                 (- ang (* pi 0.5))
