Hey guys!
If I had 3 regions like the picture, I'd like to be able to get the 2 intersecting regions (without doing them separately). Right now, I'm just getting errors :(
Side request--a LISP that uses INTERSECT without deleting the original regions (similar to this lisp for the SUBTRACT command, or this lisp that does it for polylines rather than regions)
Thanks!
I believe something like this may work.
(defun c:mintersect (/ ss1 curcmdecho curnomutt)
    (defun *error* (errmsg)
         (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
              (princ (strcat "\nError: " errmsg))
         ) ;_ end if
         (setvar 'cmdecho curcmdecho)
         (setvar 'nomutt curnomutt)
         (vla-endundomark adoc)
    ) ;_ end defun
    (vla-startundomark
         (setq adoc (vla-get-activedocument (setq acadObject (vlax-get-acad-object))))
    ) ;_ end vla-startundomark
    (setq curcmdecho (getvar 'cmdecho)
          curnomutt  (getvar 'nomutt)
    ) ;_ end setq
    (prompt "\nSelect Regions to create intersection :")
    (setq ss1 (ssget '((0 . "REGION"))))
    (prompt "\nPick points where to create intersections :")
    (setvar 'nomutt 1)
    (setvar 'cmdecho 0)
    (command-s "._-boundary" "_a" "_b" "_n" ss1 "" "_o" "_r" "" pause)
    (command "._erase" ss1 "")
    (*error* "end")
) ;_ end defun
Edited by ronsingh78
