Dear All Masters,
i have one error.i have checked by list command it shows positive coordinates. but if i export by Data extraction option it shows Negative values (Check images). why produced negative values? how to fix this issue? please find sample drawing and please guide me.
thanking you,
Best regards.
meters.dwg
Your image does not show negative coordinates. It merely shows the difference in X, and in which direction it was drawn (negative Delta X means the line was drawn from right to left)
