sivapathasunderam Posted September 7, 2016 Share Posted September 7, 2016 Dear all; Why Xref drawings also opens with the drawing It is not open in my PC, for others working on server can't able to edit the dwg thanks Siva Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 7, 2016 Share Posted September 7, 2016 Check your XLOADCTL system variable setting, you probably want it set to 2, which is the default in 2013. Quote Link to comment Share on other sites More sharing options...
sivapathasunderam Posted September 7, 2016 Author Share Posted September 7, 2016 Thanks for the help! previously it is set to 1, so now I will set to 2 I am using AutoCAD 2013 Quote Link to comment Share on other sites More sharing options...
