PAWEL17 Posted August 31, 2016 Share Posted August 31, 2016 How do i go about creating a lisp for an ARC command. I want to be able to draw an ARC around a point the same every time, 50mm radius with a 270 degree arc around a point. I Just want to input the command and select the point. I have been able to do one for a simple circle. But im struggling to follow the tutorials on this site. Help would be appreciated Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 31, 2016 Share Posted August 31, 2016 Wouldn't a block suffice? Quote Link to comment Share on other sites More sharing options...
ollie Posted August 31, 2016 Share Posted August 31, 2016 This should do what you're looking for. (vl-load-com) (defun c:tt ( / ms pt ) (setq ms (vla-get-modelspace(vla-get-activedocument(vlax-get-acad-object))) pt (vlax-3d-point(getpoint "Select insertion point"))) ;(vla-addArc model-space insertion-point radius start-angle end-angle) (vla-addArc ms pt 50 0 270) ) Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 31, 2016 Share Posted August 31, 2016 I would suggest looking into (entmake) : [b][color=BLACK]([/color][/b]defun c:sarc [b][color=FUCHSIA]([/color][/b]/ ce ra sa ia cl[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq ce [b][color=NAVY]([/color][/b]getpoint [color=#2f4f4f]"\nARC Center Point: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq ra 50 [color=#8b4513];Radius[/color] sa 0 [color=#8b4513];Start Angle[/color] ia 270 [color=#8b4513];Included Angle[/color] cl 256[b][color=FUCHSIA])[/color][/b] [color=#8b4513];Color[/color] [b][color=FUCHSIA]([/color][/b]entmake [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]cons 0 [color=#2f4f4f]"ARC"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 6 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"CELTYPE"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 8 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"CLAYER"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 10 ce[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 39 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"THICKNESS"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 40 ra[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 50 [b][color=GREEN]([/color][/b]* sa [b][color=BLUE]([/color][/b]/ pi 180[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 51 [b][color=GREEN]([/color][/b]* [b][color=BLUE]([/color][/b]+ sa ia[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]/ pi 180[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 62 cl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] It can give almost total control over entity creations -David Quote Link to comment Share on other sites More sharing options...
Grrr Posted August 31, 2016 Share Posted August 31, 2016 I would stick with David Bethel's suggestion, but to throw another option: (if (setq pt (getpoint "\nSpecify the center point for the arc: ")) (vl-catch-all-apply 'vl-cmdf (list "_.ARC" "C" "_non" pt "_non" (polar pt (angtof "0") 50) "_non" (polar pt (angtof "270") 50) )) ) EDIT: And heres another option (evaluating a list): (defun C:test ( / pt p1 p2 ) (if (setq pt (getpoint "\nSpecify the center point for the arc: ") p1 (polar pt (angtof "0") 50) p2 (polar pt (angtof "270") 50) ) (eval '(command "_.ARC" "C" "_non" pt "_non" p1 "_non" p2)) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 31, 2016 Share Posted August 31, 2016 Sorry to pick at your code but - (if (setq pt (getpoint "\nSpecify the center point for the arc: ")) (vl-catch-all-apply 'vl-cmdf (list "_.ARC" "C" "_non" pt "_non" (polar pt (angtof "0") 50) "_non" (polar pt (angtof "270") 50) )) ) Why the use of vl-catch-all-apply here? EDIT: And heres another option (evaluating a list): (defun C:test ( / pt p1 p2 ) (if (setq pt (getpoint "\nSpecify the center point for the arc: ") p1 (polar pt (angtof "0") 50) p2 (polar pt (angtof "270") 50) ) (eval '(command "_.ARC" "C" "_non" pt "_non" p1 "_non" p2)) ) (princ) ) The use of eval seems redundant here - removing the eval function and single quote would produce the same result. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 31, 2016 Share Posted August 31, 2016 I would stick with David Bethel's suggestion, but to throw another option: (if (setq pt (getpoint "\nSpecify the center point for the arc: ")) (vl-catch-all-apply 'vl-cmdf (list "_.ARC" "C" "_non" pt "_non" (polar pt (angtof "0") 50) "_non" (polar pt (angtof "270") 50) )) ) What is the need or the use of the vl-catch-* function in your example? EDIT: And heres another option (evaluating a list): Just hit enter when the program asks you to specify center point. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 31, 2016 Share Posted August 31, 2016 Here's another example to account for changes to the UCS: (defun c:qarc ( / c z ) (setq z (trans '(0 0 1) 1 0 t)) (while (setq c (getpoint "\nArc center: ")) (entmake (list '(000 . "ARC") '(040 . 50.0) '(050 . 0.0) '(051 . 4.712388980384689) (cons 010 (trans c 1 z)) (cons 210 z) ) ) ) (princ) ) Or with the arc angle aligned to the UCS: (defun c:qarc ( / a b c z ) (setq z (trans '(0 0 1) 1 0 t) a (angle '(0 0) (trans (getvar 'ucsxdir) 0 z t)) b (+ a 4.712388980384689) ) (while (setq c (getpoint "\nArc center: ")) (entmake (list '(000 . "ARC") '(040 . 50.0) (cons 050 a) (cons 051 b) (cons 010 (trans c 1 z)) (cons 210 z) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
PAWEL17 Posted August 31, 2016 Author Share Posted August 31, 2016 That's the thing, i want to eliminate the need for a block Quote Link to comment Share on other sites More sharing options...
PAWEL17 Posted August 31, 2016 Author Share Posted August 31, 2016 I would suggest looking into (entmake) : [b][color=BLACK]([/color][/b]defun c:sarc [b][color=FUCHSIA]([/color][/b]/ ce ra sa ia cl[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq ce [b][color=NAVY]([/color][/b]getpoint [color=#2f4f4f]"\nARC Center Point: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq ra 50 [color=#8b4513];Radius[/color] sa 0 [color=#8b4513];Start Angle[/color] ia 270 [color=#8b4513];Included Angle[/color] cl 256[b][color=FUCHSIA])[/color][/b] [color=#8b4513];Color[/color] [b][color=FUCHSIA]([/color][/b]entmake [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]cons 0 [color=#2f4f4f]"ARC"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 6 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"CELTYPE"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 8 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"CLAYER"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 10 ce[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 39 [b][color=GREEN]([/color][/b]getvar [color=#2f4f4f]"THICKNESS"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 40 ra[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 50 [b][color=GREEN]([/color][/b]* sa [b][color=BLUE]([/color][/b]/ pi 180[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 51 [b][color=GREEN]([/color][/b]* [b][color=BLUE]([/color][/b]+ sa ia[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]/ pi 180[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cons 62 cl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] It can give almost total control over entity creations -David This is excellent, along the lines of what i was trying to create Is it possible to take the layer of the line/polyline its being created on, instead of having to match properties after its created? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 1, 2016 Share Posted September 1, 2016 Maybe [b][color=#ff00ff]([/color][/b]initget 1[b][color=fuchsia])[/color][/b] (setq clay (cdr (assoc 8 (entget (car (entsel "Pick an object for layer")))))) [b][color=fuchsia]([/color][/b]setq ce [b][color=navy]([/color][/b]getpoint [color=#2f4f4f]"\nARC Center Point: "[/color][b][color=navy])[/color][/b][b][color=fuchsia])[/color][/b] [b][color=#ff00ff]................[/color][/b] [b][color=#800000]([/color][/b]cons 8 clay) ................ Quote Link to comment Share on other sites More sharing options...
David Bethel Posted September 1, 2016 Share Posted September 1, 2016 Lee, just out of curiosity, why the (trans) call on the center point ? Here's another example to account for changes to the UCS:(defun c:qarc ( / c z ) (setq z (trans '(0 0 1) 1 0 t)) (cons 010 (trans c 1 z)) (cons 210 z) ) ) ) (princ) ) I can't think of a scenario that would apply. Thanks -David Quote Link to comment Share on other sites More sharing options...
David Bethel Posted September 1, 2016 Share Posted September 1, 2016 (edited) To do the operation with a single click would probably take something like this: [b][color=BLACK]([/color][/b]defun c:sarc1 [b][color=FUCHSIA]([/color][/b]/ la ce ra sa ia cl ss a d[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ce[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]initget 1[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ce [b][color=MAROON]([/color][/b]osnap [b][color=GREEN]([/color][/b]getpoint [color=#2f4f4f]"\nARC Base Point: "[/color][b][color=GREEN])[/color][/b] [color=#2f4f4f]"NEA,END"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]cond [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]/= 1 [b][color=GREEN]([/color][/b]sslength [b][color=BLUE]([/color][/b]setq ss [b][color=RED]([/color][/b]ssget [color=#2f4f4f]"C"[/color] ce ce [b][color=PURPLE]([/color][/b]list [b][color=TEAL]([/color][/b]cons 0 [color=#2f4f4f]"*LINE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]alert [color=#2f4f4f]"Multiple LINE Entities Found At This Point"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]T [b][color=MAROON]([/color][/b]setq a [b][color=GREEN]([/color][/b]* pi 0.25[b][color=GREEN])[/color][/b] d [b][color=GREEN]([/color][/b]/ [b][color=BLUE]([/color][/b]getvar [color=#2f4f4f]"VIEWSIZE"[/color][b][color=BLUE])[/color][/b] 33[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]grdraw [b][color=GREEN]([/color][/b]polar ce [b][color=BLUE]([/color][/b]* a 1[b][color=BLUE])[/color][/b] d[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]polar ce [b][color=BLUE]([/color][/b]* a 5[b][color=BLUE])[/color][/b] d[b][color=GREEN])[/color][/b] 6 1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]grdraw [b][color=GREEN]([/color][/b]polar ce [b][color=BLUE]([/color][/b]* a 3[b][color=BLUE])[/color][/b] d[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]polar ce [b][color=BLUE]([/color][/b]* a 7[b][color=BLUE])[/color][/b] d[b][color=GREEN])[/color][/b] 6 1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq la [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 8 [b][color=RED]([/color][/b]entget [b][color=PURPLE]([/color][/b]ssname ss 0[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513];Layer[/color] ra 50 [color=#8b4513];Radius[/color] sa 0 [color=#8b4513];Start Angle[/color] ia 270 [color=#8b4513];Included Angle[/color] cl 256[b][color=MAROON])[/color][/b] [color=#8b4513];Color[/color] [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"ARC"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 6 [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CELTYPE"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 8 la[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 10 ce[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 39 [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"THICKNESS"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 40 ra[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 50 [b][color=RED]([/color][/b]* sa [b][color=PURPLE]([/color][/b]/ pi 180[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 51 [b][color=RED]([/color][/b]* [b][color=PURPLE]([/color][/b]+ sa ia[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]/ pi 180[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 62 cl[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 210 [b][color=RED]([/color][/b]trans '[b][color=PURPLE]([/color][/b]0 0 1[b][color=PURPLE])[/color][/b] 1 0[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] This would defintlty need testing. And probably more error trapping. -David Edited September 1, 2016 by David Bethel Add forced input Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 1, 2016 Share Posted September 1, 2016 Lee, just out of curiosity, why the (trans) call on the center point ? I can't think of a scenario that would apply. Thanks -David Since coordinates for most planar entities (with some exceptions) are expressed relative to the Object Coordinate System (OCS), the points must be transformed from the active UCS to the OCS, which may be calculated using the normal vector for the active UCS plane (using the Arbitrary Axis Algorithm, or more conveniently, the trans function). As an example, try the following with the UCS rotated about the Z-axis (by any angle): (defun c:qarc ( / c z ) (setq z (trans '(0 0 1) 1 0 t)) (while (setq c (getpoint "\nArc center: ")) (entmake (list '(000 . "ARC") '(040 . 50.0) '(050 . 0.0) '(051 . 4.712388980384689) '(062 . 3) (cons 010 (trans c 1 z)) (cons 210 z) ) ) (entmake (list '(000 . "ARC") '(040 . 50.0) '(050 . 0.0) '(051 . 4.712388980384689) '(062 . 1) (cons 010 c) (cons 210 z) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
David Bethel Posted September 2, 2016 Share Posted September 2, 2016 OK Rotated UCS. I see how that could be a problem Thanks for explaination! -David Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 3, 2016 Share Posted September 3, 2016 No worries! Quote Link to comment Share on other sites More sharing options...
Erhanask Posted July 19, 2020 Share Posted July 19, 2020 Well... radius if we want to give Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 20, 2020 Share Posted July 20, 2020 On 7/19/2020 at 11:58 AM, Erhanask said: Well... radius if we want to give You can add an extra getdist prompt, e.g.: (defun c:qarc ( / a b c r z ) (setq z (trans '(0 0 1) 1 0 t) a (angle '(0 0) (trans (getvar 'ucsxdir) 0 z t)) b (+ a 4.712388980384689) ) (while (and (setq c (getpoint "\nArc center: ")) (setq r (getdist c "\nSpecify arc radius: ")) ) (entmake (list '(000 . "ARC") (cons 040 r) (cons 050 a) (cons 051 b) (cons 010 (trans c 1 z)) (cons 210 z) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Erhanask Posted July 21, 2020 Share Posted July 21, 2020 Thank you very much….. health to your hands Quote Link to comment Share on other sites More sharing options...
Erhanask Posted March 8, 2021 Share Posted March 8, 2021 Hello there, Can it get the radius I wrote earlier until I write the new radius. for example; I'll draw 10 arcs of the same diameter and I'll draw 15 identical arcs of another diameter. Is it possible not to write the diameter for each of them one by one? I will be glad if you help Quote Link to comment Share on other sites More sharing options...
