I'm found a lisp to change a point Z coord by entmod, but I also want to change the color number. I tried this code:
(defun c:ELEVAZIONE (/ ss i sn pts txt d di e ent)
;;;   ==-- Author : Tharwat Al Shoufi --== 	;;;
;;; Entmod the Z value of Points according	;;;
;;; 	  to the nearest text's value 		;;;
 (if (setq ss (ssget '((0 . "POINT,*TEXT"))))
     (setq sn (ssname ss (setq i (1- i))))
     (if (eq (cdr (assoc 0 (entget sn))) "POINT")
       (setq pts (cons (list (cdr (assoc 10 (entget sn))) sn) pts))
       (setq txt (cons (list (cdr (assoc 10 (entget sn))) sn) txt))
 (foreach p pts
   (foreach x txt
     (if (not d)
       (setq d (distance (car p) (car x))
             e (cadr x)
       (if (< (setq di (distance (car p) (car x))) d)
         (setq d di
               e (cadr x)
   (setq d nil)
(if (numberp (read (cdr (assoc 1 (entget e)))))
  (entmod
       (subst
         (cons 10
               (list (car (cdr (assoc 10 (setq ent (entget (cadr p))))))
                     (cadr (cdr (assoc 10 ent)))
         (assoc 10 ent)
         ent
	(entmod (subst (cons 62 1) (assoc 62 ent) ent)) ; this is my code
 (princ "\n Written by Tharwat Al Shoufi")
but doesn't work. Can someone help me?
I updated the code this way and it seems to work:
 (foreach p pts
   (foreach x txt
     (if (not d)
             e (cadr x)
         (setq d di
               e (cadr x)
   (setq d nil)
(setq elist
	(subst
         (cons 10
         (assoc 10 ent)
         ent
(setq elist (subst (cons 62 1) (assoc 62 elist) elist))
(entmod elist)
 (princ "\n Fatto!")
You will need to address entities that have color BYLAYER as well
[b][color=BLACK]([/color][/b]setq elist [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]assoc 62 elist[b][color=NAVY])[/color][/b]
               [b][color=NAVY]([/color][/b]subst [b][color=MAROON]([/color][/b]cons 62 1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]assoc 62 elist[b][color=MAROON])[/color][/b] elist[b][color=NAVY])[/color][/b]
               [b][color=NAVY]([/color][/b]append elist [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 62 1[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
