dick69 Posted August 30, 2016 Share Posted August 30, 2016 Hi mates, any idea to get the geo-coordinates of a Position Marker (new entity in Autocad 2016)? I tried to extract like a block attributes, but it doesn't work. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted August 31, 2016 Share Posted August 31, 2016 (edited) (vl-load-com) (defun c:test () (setq p (getPositionMarkerCoords)) (princ (strcat "\nNorthing: " (rtos (cadr p) 2 3) "\nEasting: " (rtos (car p) 2 3))) (princ) ) (defun getPositionMarkerCoords ( / ad s ds ts rp le ln p) (setq ad (_GetAeccDocument)) (setq s (vlax-get-property ad 'Settings)) (setq ds (vlax-get-property s 'DrawingSettings)) (setq ts (vlax-get-property ds 'TransformationSettings)) (setq rp (vlax-get-property ts 'ReferencePoint)) (setq le (vlax-get-property rp 'LocalEasting)) (setq ln (vlax-get-property rp 'LocalNorthing)) (setq p (list le ln)) ) (defun _GetAeccDocument () ((lambda (vrsn) (if (setq vrsn (cond ((vl-string-search "21.0" vrsn) "11.0") ; 2017 ((vl-string-search "20.1" vrsn) "10.5") ; 2016 ((vl-string-search "20.0" vrsn) "10.4") ; 2015 ((vl-string-search "19.1" vrsn) "10.3") ; 2014 ((vl-string-search "19.0" vrsn) "10.0") ; 2013 ((vl-string-search "18.2" vrsn) "9.0") ; 2012 ((vl-string-search "18.1" vrsn) "8.0") ; 2011 ((vl-string-search "18.0" vrsn) "7.0") ; 2010 ((vl-string-search "17.2" vrsn) "6.0") ; 2009 ((vl-string-search "17.1" vrsn) "5.0") ; 2008 ) ) (setq *AeccDoc* (vlax-get (cond (*AeccApp*) ((setq *AeccApp* (vla-getinterfaceobject (cond (*Acad*) ((setq *Acad* (vlax-get-acad-object))) ) (strcat "AeccXUiLand.AeccApplication." vrsn) ) ) ) ) 'ActiveDocument ) ) ) ) (if vlax-user-product-key ; If 2013+ (vlax-user-product-key) ; Use new function (vlax-product-key) ; Use legacy function ) ) ) Edited August 31, 2016 by Hippe013 Code Tags (My Bad) - Added / to make variables local Quote Link to comment Share on other sites More sharing options...
a_67vdub Posted August 31, 2016 Share Posted August 31, 2016 Hi Hippe013, Thanks for posting the code. However in order to make it work I had to add a "/" to the local variables area of the getpositionmarkercoords function because they look like arguments as you posted it. Also, in the same function you are declaring the variable "ne" as local, but I think you mean for that to be "ln". Thanks again, Steve Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted August 31, 2016 Share Posted August 31, 2016 Steve, Thanks for the catch. I threw this together rather quickly from other code that I had. I will update my code above. regards, Hippe013 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 1, 2016 Share Posted September 1, 2016 Hippe013 thanks for the 2017 vrsn saves me from finding it, if we ever got to 2017 more likely 2018. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted September 2, 2016 Share Posted September 2, 2016 Please lengthen your message to at least 10 characters. Quote Link to comment Share on other sites More sharing options...
dick69 Posted September 5, 2016 Author Share Posted September 5, 2016 Thanks for the code vdub, but when I execute it on autocad, return me the next error: "; error: Automation Error. Problem in loading application". I've check the lisp and I think that the problem is on "getPositionMarkerCoords" function that it doesn't run. (I've Autocad 2016 release) Thanks a lot for your support, Greetings. Quote Link to comment Share on other sites More sharing options...
a_67vdub Posted September 5, 2016 Share Posted September 5, 2016 To be fair, I didn't post the code, Hippe013 did. Quote Link to comment Share on other sites More sharing options...
dick69 Posted September 6, 2016 Author Share Posted September 6, 2016 Ups... It's true, I'm sorry Hippe, I was confused! I hope you can help me to run your routine. Thanks. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted September 6, 2016 Share Posted September 6, 2016 The routine that I created above works only with Civil 3D with the versions stated above. As of right now I am not certain how to gain access to the geo-location data (using visual lisp) without using Aecc. I should be able to write a lisp function using vb.net to expose the geo-location data without the use of Aecc (Civil 3D). This may take a little while depending on how well exposed you need it. ie. Just retrieve data vs. setting data. regards, Hippe013 Quote Link to comment Share on other sites More sharing options...
a_67vdub Posted September 6, 2016 Share Posted September 6, 2016 Re-reading the OP, it sounds like you just want the coordinates of the Position Marker Entity that's similar to a multileader, correct? If so, the following should do it (you can select as many of them as you want). I wasn't sure if you wanted the LatLongs, or Cartesian coordinates, so it displays both. HTH ;;Get Position Marker Geo-Coordinates ;; ;;By Steve Carson ;; (vl-load-com) (defun c:PMCoords ( / ss obj) (setq ss (ssget '((0 . "POSITIONMARKER")))) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (princ (strcat "\n" (vla-get-TextString obj))) (princ (strcat "\nNorthing: " (rtos (cadr (vlax-safearray->list (vlax-variant-value (vla-get-Position obj) ) ) ) 2 )) (princ (strcat "\nEasting: " (rtos (car (vlax-safearray->list (vlax-variant-value (vla-get-Position obj) ) ) ) 2 )) (princ (strcat "\nLatitude: " (vla-get-Latitude obj))) (princ (strcat "\nLongitude: " (vla-get-Longitude obj))) (princ "\n") ) (textscr) (princ) ) Steve Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted September 6, 2016 Share Posted September 6, 2016 I was under the understanding that the OP wanted the GEO-Location position rather than the location of a position marker. Your code works fine for this. I would be curious as to how extract the location of the GeoMarker (Red Dot) without the benefits of the Aecc document. I've attached an image showing the Geo-Location Marker that I was referring to. Quote Link to comment Share on other sites More sharing options...
CodeDing Posted September 29, 2020 Share Posted September 29, 2020 Hippe013, Just doing some digging into this today, I know I'm a few years late, but it may benefit somebody still. Best, ~DD (defun GetGeoData ( / ) (dictsearch (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" "*Model_Space"))))))) "ACAD_GEOGRAPHICDATA" );dictsearch );defun (defun c:TEST ( / geoData ptGeo) (if (and (setq geoData (GetGeoData)) (not (zerop (getvar 'TILEMODE)))) (progn (setq ptGeo (cdr (assoc 10 geoData))) (command "_.CIRCLE" "non" ptGeo (* 0.15 (getvar 'VIEWSIZE))) (prompt "\nA circle was created at the point: ") (princ ptGeo) );progn ;else (prompt "\nEither No Geo Data or not in Model space...") );if (princ) );defun Quote Link to comment Share on other sites More sharing options...
rog1n Posted April 20, 2022 Share Posted April 20, 2022 Hello, is possible to set GeoData? Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted April 21, 2022 Share Posted April 21, 2022 On 9/6/2016 at 7:46 PM, a_67vdub said: Re-reading the OP, it sounds like you just want the coordinates of the Position Marker Entity that's similar to a multileader, correct? If so, the following should do it (you can select as many of them as you want). I wasn't sure if you wanted the LatLongs, or Cartesian coordinates, so it displays both. HTH ;;Get Position Marker Geo-Coordinates ;; ;;By Steve Carson ;; (vl-load-com) (defun c:PMCoords ( / ss obj) (setq ss (ssget '((0 . "POSITIONMARKER")))) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (princ (strcat "\n" (vla-get-TextString obj))) (princ (strcat "\nNorthing: " (rtos (cadr (vlax-safearray->list (vlax-variant-value (vla-get-Position obj) ) ) ) 2 )) (princ (strcat "\nEasting: " (rtos (car (vlax-safearray->list (vlax-variant-value (vla-get-Position obj) ) ) ) 2 )) (princ (strcat "\nLatitude: " (vla-get-Latitude obj))) (princ (strcat "\nLongitude: " (vla-get-Longitude obj))) (princ "\n") ) (textscr) (princ) ) Steve That code seems to be missing 2 closing ) characters, I presume at the the (princ (strcat. Quote Link to comment Share on other sites More sharing options...
