Change entity layer
RubberDinero
At my job, i have a very tedious job of changing layers from proposed to existing and vice versa
our layer setup is very basic
"LayerName"=existing layer
"LayerName-PR"=Proposed layer.
i have recently bought a book to to learn AutoLisp and I've gotten the basic concept.
I know that i want to ssget LayerName and setq that name to L then CHPROP LA to L-PR.
but i want to know if someone has anything like this already and could help me.
I'd like to do a mass select and have it automatically change the entities to their respective PR layer. also vice versa, to remove PR.
i'm not looking for a layer renaming lisp. i'm looking for a entity layer changing lisp. anything helps. thanks.
Are you looking to change everything on "LayerName" to "LayerName-PR", including nested objects? Or only objects selected by a user?
Selected items via box selection or pickbox. i would like to layiso a bunch of layers select the entities and run the lisp. or run the lisp and select the entities.
It would have to be different then renaming a layer, because there are going to be some items on the same layer i don't want to change to -pr or remove the pr, they have to remain.
thanks.
The following is quickly written using some existing code:
(defun c:lay2pr ( / enx idx lay sel )
   (if (setq sel (ssget "_:L" '((8 . "~*-PR"))))
       (repeat (setq idx (sslength sel))
           (setq enx (entget (ssname sel (setq idx (1- idx))))
                 lay (assoc 8 enx)
           (entmod (subst (cons 8 (matchlayer (cdr lay) (strcat (cdr lay) "-PR"))) lay enx))
(defun c:pr2lay ( / enx idx lay sel )
   (if (setq sel (ssget "_:L" '((8 . "*?-PR"))))
                 lay (assoc 8 enx)
           (entmod (subst (cons 8 (matchlayer (cdr lay) (substr (cdr lay) 1 (- (strlen (cdr lay)) 3)))) lay enx))
(defun matchlayer ( src new )
   (or (tblsearch "layer" new)
       (entmake
           (subst
               (cons 2 new)
               (cons 2 src)
               (vl-remove-if '(lambda ( x ) (member (car x) '(-1 5 102 360))) (entget (tblobjname "layer" src)))
   new
The commands are LAY2PR and PR2LAY.
                 lay (assoc 8 enx)
                 lay (assoc 8 enx)
       (entmake
           (subst
               (cons 2 new)
               (cons 2 src)
   new
Wow! that was amazing and fast! i'm going to study this code.
I'm not a programmer so I'm reading "AutoLisp in Plain English" very interesting stuff! the book even came with a floppy disk.
thank you very much!
do i have to do like a solution found option and pick your response?
I would suggest you to start with afralisp.com, and after reaching certain level to visit Lee Mac's tutorials: http://www.lee-mac.com/tutorials.html
And after reading your comments I don't think you'll "study" too much from his code at this point (no offense), since usually LM's codes are written in advanced/high level - avoiding any possible faults in them.
Thanks. what would you suggest from afralisp? it's pretty much a book list from amazon. that's where i bought my book. since it seemed to be for noobs, i felt it was perfect for me.
I've already written some very basic lsp
(defun c:wa nil
(setq s (ssget "_X" '((8 . "*water*,*watr*,*wtr*,*wa-*"))))
(command "_.chprop" s "" "LA" "VU-WATR-PIPE""")
I know its just an "ssx macro" turned lsp, but i was kind of proud of myself.
afralisp.com
I think this website if no longer in service.
You're very welcome - feel free to ask if you have questions regarding the posted code.
Not at all - a 'thank you' is more than sufficient. :)
When posting code to the forum, I would also suggest you read these guidlines to correctly format the code.
When writing your code, I would also strongly suggest using a code editor if you are not already doing so -
Personally, I find that the Visual LISP IDE provided with AutoCAD is by far the most suitable for writing AutoLISP:
The Visual LISP Editor - Part 1
The Visual LISP Editor - Part 2
An Introduction to the Visual LISP IDE
Retrieving Information About a Function
A Shortcut to Localising Variables
Debugging Code with the Visual LISP IDE
  • 6 years later...
I am having a similar need except my layer names are a bit different.  I-EQPT-21, for instance, will change to XI-EQPT-81 representing a change from new to existing.    In other cases, the opposite is true.  The numbers represent the layer color and the X represents "existing".  I was able to modify the code above to make the change from I-EQPT-21 to XI-EQPT-81 by selection method noted but can't figure out how to go in reverse.  I can tell that the ENTMOD code removes the last 3 characters of the layer name when switching back.  Obviously, I don't need that to happen.  Is it possible to easily do what I need without completely rewriting the code?  Thanks a bunch for any tips.
