comcu Posted August 26, 2016 Posted August 26, 2016 Hi, my new company are using autocad LT and dim everything in paper space. I have no choice in the matter so am trying to follow procedure. I can see the benefits of it but have had a few errors which is causing me problems. basicially the dimension are not reading the vaule they should. for example I have a drawing with a view port of 1:16 (don't ask) and dimensioned from two points a value of 2400mm. I then continued drawing and at some point have went back and noticed the dim now reads 38,400mm. this is happening often and I can see the relation of the sizes, 2400 x 16 = 38,400mm. this has had me stumped and I started deleting dims and then redoing them and then noticed if I match properties it would go back to 2400mm. I then noticed today that if I select the dim and go to the properties window and "Primary Units" the "dim linear scale" value is "-255.9999" I then changed the value to "1" and then dim corrects itself. I did notice that the value in the properties changed from "1" to "-16" as soon as I type "1" and enter. Now I know that before I print I do a select all, filter rotated dims and change value to "1" this should solve the problem but this feels like a work around and I must be missing something. many thanks for any help. I have search online and have found an answer altho quite a few mentions. Quote
BIGAL Posted August 26, 2016 Posted August 26, 2016 In your dimstyle you would need the scale factor set to match the viewport scaling so when you pick two points you get 2400. Post a dwg easier to see whats going on, 1/16 and metric is odd, 0.05 would be better than 0.0625 Quote
SLW210 Posted August 29, 2016 Posted August 29, 2016 You need to be using Associative Dimensions (DIMASSOC=2) and make sure you are snapping to real places in model space (EndPoint, MidPoint, Intersection and Center). You may need to use DIMREASSOCIATE and/or DIMREGEN to update associative dimensions. Also note: Although associative dimensions support most object types that you would expect to dimension, they do not support the following: •Hatches •Multiline objects •2D solids •Objects with nonzero thickness •Images •DWF underlays Associativity is not maintained between a dimension and a block reference if the block is redefined. Associativity is not maintained between a dimension and a 3D solid if the shape of the 3D solid is modified. Dimensions created with QDIM are not associative but may be associated individually with DIMREASSOCIATE. Quote
