blackmember Posted August 19, 2016 Posted August 19, 2016 Hi all! I have a CAD file with contour lines. Just need to add elevation information to the lines so it helps me to determine heights when making a model. Thanks https://www.dropbox.com/s/ldzutpphz5csyjo/1.DWG?dl=0 Quote
ReMark Posted August 19, 2016 Posted August 19, 2016 Are you asking about labeling each contour line with its perceived elevation? Quote
blackmember Posted August 19, 2016 Author Posted August 19, 2016 ReMark said: Are you asking about labeling each contour line with its perceived elevation? Yep! Is there a way I can do it in AutoCAD or do I need Civil? I downloaded Civil just in case. Quote
ReMark Posted August 19, 2016 Posted August 19, 2016 There is no command native to AutoCAD that could do it although there could be a custom lisp routine that is capable. I don't know as I don't work with contour maps in my line of work. A search would be required. Quote
TheCADnoob Posted August 19, 2016 Posted August 19, 2016 must be a home work assignment http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/elevations/td-p/6510639 edit: BTW there is a dwg with the elevations labeled in the linked thread. Quote
BIGAL Posted August 19, 2016 Posted August 19, 2016 The post above is a good idea a simple lisp would get the z value and write as text. (while (setq obj(vlax-ename->vla-object (car (entsel "\nPick contour nothing to exit")))) (setq z (vla-get-elevation obj)) (command "Text" (getpoint) 1 0 (rtos z 2 3)) ; note text style height = 0 ;(command "Text" (getpoint) 1 (rtos z 2 3)) ; note text style height is set ) Quote
MillerMG Posted August 30, 2016 Posted August 30, 2016 where are you located with elevations like that? In my area the highest usually is around the 500s. I assume you would like to avoid clicking each polyline and inputting the elevation into the properties? Quote
