gkumar0231 Posted August 16, 2016 Posted August 16, 2016 Can anyone please create lisp for Plot Previous with window Selection, i need this urgent. , i have these frames ansd i want create PDF each frame Separate, Quote
BIGAL Posted August 16, 2016 Posted August 16, 2016 Gkumar0231 start a new post and delete this one, like others I have the answer I think but you must ask in the correct way not just add to a post. The administrator will soon sort this out. Quote
SLW210 Posted August 16, 2016 Posted August 16, 2016 I have created a new thread for your question. Lisp for Plot previous with window selection in the AutoLISP, Visual LISP & DCL Forum. Quote
rlx Posted August 16, 2016 Posted August 16, 2016 Assuming your last plot was succesfull and you are in paperspace : ;(command PlotCommand DetailedPlot LayoutName PrinterName PaperSize PlotUnits Orientation ; PlotUpsideDown PlotArea 1stCorner 2ndCorner PlotScale PlotOffset ; PlotWithStyles PlotStyleName PlotWithLineWeights ScaleLineWeight PlotPaperSpaceFirst ; HidePaperspaceObjects WritePlotToFile SaveChangesToTab ProceedWithPlot) (defun c:plot_pw ( / 1stCorner 2ndCorner) (while (and (setq 1stCorner (getpoint "\nEnter 1st corner : ")) (setq 2ndCorner (getcorner 1stCorner "\nEnter 2nd corner : "))) (command "-plot" "y" "" "" "" "" "" "" "window" 1stCorner 2ndCorner "" "" "" "" "" "" "" "" "" "" ""))) gr. Rlx Quote
BIGAL Posted August 17, 2016 Posted August 17, 2016 This is a model space version same applies in a layout it will find all title blocks and plot them. Me personally 1 title block per layout. A quick and dirty use CHSPACE and the code below will work once you set the correct block name and sheet size etc. (PROMPT ".....PRINTING DRAWING TO plotter....") (setq oldsnap (getvar "osmode")) (setvar "osmode" 0) (setq ss2 (ssget "x" '((0 . "INSERT")(2 . "Da1drsht")(410 . "Model")))) ; da1drsht is the name of the title block 410 is the space ; for this post remove the (410 . "Model") ; and have a (if (/= "model" (getvar "ctab")) (setq n (sslength ss2)) (setq index 0) (repeat n (setq en (ssname ss2 index)) (setq el (entget en)) (setq inspt (assoc 10 el)) ; insertion pt (setq xmin (- (cadr inspt) 6.0)) (setq ymin (- (caddr inspt) 6.0)) (setq xymin (strcat (rtos xmin 2 1) "," (rtos ymin 2 1))) (setq xmax (+ xmin 813.0)) ; hard coded for 813 wide 6mm offset (setq ymax (+ ymin 566.0)) ;hard coded for 566 high (setq xymax (strcat (rtos xmax 2 1) "," (rtos ymax 2 1))) (COMMAND "-PLOT" "Y" "" "//PRODPRN01/Design-5100" "A3" "M" "LANDSCAPE" "N" "W" xymin xymax "1=2" "C" "y" "Designlaser.ctb" "Y" "" "n" "n" "y" ) (setq index (+ index 1)) ) (setvar "osmode" oldsnap) (princ) Quote
