is it possible to get the Start X Y Z and End X Y Z of a line to clipboard??
i needed to manually copy the coordinates and say paste it to text file?..
you know? CTRL+V it so somewhere else?
because i have this Macro code and i dont know much about lisp on how am i gonna get the XYZ coordinates into clipboard. so that i can use the macro to search the coordinared on extracted excel files
can someone help me make a lisp routine to only clipboard the x y z coordinates of a LINE?
so i can literally CTRL+V it to anywhere, weather its on excel cells, text, word, anywhere i can use CTRL+V shortcut key..
Try the following:
(defun c:l2c ( / ent )
   (if (setq ent (LM:selectifobject "\nSelect line: " "LINE"))
       (if (LM:copytoclipboard
               (LM:lst->str
                   (mapcar 'rtos
                       (append
                           (cdr (assoc 10 (entget ent)))
                           (cdr (assoc 11 (entget ent)))
                   "\t"
           (princ "\nLine endpoints copied to clipboard.")
;; Same method as MP demonstrates here: http://bit.ly/170kacW
(defun LM:copytoclipboard ( str / clp htm par rtn )
   (if (setq htm (vlax-create-object "htmlfile"))
           (setq rtn
               (vl-catch-all-apply
                  '(lambda ( )
                       (setq par (vlax-get htm 'parentwindow)
                             clp (vlax-get par 'clipboarddata)
                       (vlax-invoke clp 'setdata "Text" str)
           (foreach obj (list clp par htm)
               (if (= 'vla-object (type obj))
                   (vlax-release-object obj)
           (if (not (vl-catch-all-error-p rtn)) str)
;; Select if Object  -  Lee Mac
;; Continuously prompts the user for a selection of a specific object type
(defun LM:selectifobject ( msg typ / ent )
   (while
       (progn (setvar 'errno 0) (setq ent (car (entsel msg)))
           (cond
               (   (= 7 (getvar 'errno))
                   (princ "\nMissed, try again.")
               (   (null ent) nil)
               (   (not (wcmatch (cdr (assoc 0 (entget ent))) typ))
                   (princ "\nInvalid object selected.")
   ent
;; List to String  -  Lee Mac
;; Concatenates each string in a supplied list, separated by a given delimiter
;; lst - [lst] List of strings to concatenate
;; del - [str] Delimiter string to separate each item
(defun LM:lst->str ( lst del )
   (if (cdr lst)
       (strcat (car lst) del (LM:lst->str (cdr lst) del))
       (car lst)
(vl-load-com) (princ)
Try the following:
               (LM:lst->str
                   (mapcar 'rtos
                       (append
                   "\t"
           (setq rtn
               (vl-catch-all-apply
                  '(lambda ( )
   (while
           (cond
               (   (null ent) nil)
   ent
   (if (cdr lst)
       (car lst)
EXACTLY WHAT i needed!!!! thank you so much! i can now use this! OMG your genius!
You're welcome!
sir one question...
i cant use the command:
"Select P" anymore after selecting the line, how na i change the way i select the line?
sir one question...
Please try the following modified code:
   (if (or (and (setq ent (ssget "_I" '((0 . "LINE"))))
                (setq ent (ssname ent 0))
               (LM:lst->str
                   (mapcar 'rtos
                       (append
                   "\t"
           (setq rtn
               (vl-catch-all-apply
                  '(lambda ( )
   (while
           (cond
               (   (null ent) nil)
   ent
   (if (cdr lst)
       (car lst)
