I finished everything that I needed to input and play around with in autolisp. I want to make the whole program better by design a GUI for it. However, from what I understand, autolisp is not able to accomplish it. Is it possible? If not, is there a way to design GUI in TCL or Java then import the data to autocad? I am pretty new to programming. Thanks in advance to any answers!
Using DCL you can create a dialog box for your AutoLISP application. If the limited features of DCL are not enough, you should look at OpenDCL first.
Thanks! I have a follow up question, though. Is there a way for DCL to redirect you to a next interface? Not necessarily another file, but kind of like a slide that redirect you from menu to menu.
Dcl supports sub menus so you can pick a subject and have more dialouge choices.
