It would make more sense to create the object in the 1st instance as you draft rather than doing as a second pass it looks like only 3 or 4 blocks would be required. To do manually with some improvements would need a bit of thinking, a couple of ideas come to mind, dragging a pline over the circles would alow multiple solids to be created. Likewise the squares.
It would be far easier to match the circle rad and insert a 3d block at this point. All the same size 1 go, you appear to have a couple of sizes. Only prob is the squares are the same radius. can they be 0.001 different.
  • Replies 20
  • tmd_63
    9
  • RobDraw
    6
  • BIGAL
    3
  • SLW210
    2
Posted Images
