samifox Posted June 30, 2016 Posted June 30, 2016 hi when binding xref, the operation is canceled in case there are orphaned drawing referenced. how can i ignore those operands so the bind process will be done. Thanks S Quote
rlx Posted June 30, 2016 Posted June 30, 2016 (edited) haven't read all the reactions in this link but maybe it can be usefull? http://www.cadtutor.net/forum/showthread.php?9225-xrefs-driving-me-mad!-Can-t-detach if it's allways the same file you could consider making a 'dummy' xref and than you can detach it... good luck gr. Rlx Edited June 30, 2016 by rlx Quote
