Wwx95 Posted June 24, 2016 Posted June 24, 2016 What I will select is a 3d polyline. (defun c:coord ( / e r) (prompt "\nchoose a onject!") (setq e (entget (car (entsel)))) (setq r 1) (setq count 0) (while r (setq e (entget (entnext (cdr (car e))))) (if (/= (cdr (assoc 0 e)) "SEQEND") (progn (terpri) (princ (cdr (assoc 10 e))) ;print the co-ordinates (setq count(1+ count)) ) (setq r nil) ) ) (prompt "\nThere are total " );In here how to print "There are total (count ;number) vertexes in this object." (princ) );defun (princ) Do I express clear??I want to put the variable "count' in the prompt,for example,I got the count equal to 4,what I want to do is to print on the screen: "There are total 4 vertexes in this object."is that possible?Thanks. Quote
BKT Posted June 25, 2016 Posted June 25, 2016 Change your prompt code to: (prompt (strcat "\nThere are total " (itoa count) " vertices in this object")) Quote
Grrr Posted June 25, 2016 Posted June 25, 2016 Alternatively: (princ "\nThere are total ") (print (itoa count)) (princ " vertices in this object.") But I usually use BKT's example. Quote
Tharwat Posted June 25, 2016 Posted June 25, 2016 Have a look at the following mods: (defun c:3dCoords (/ i s e) (if (and (setq i 0 s (car (entsel "\nPick on 3Dpolyline :"))) (member '(100 . "AcDb3dPolyline") (entget s)) ) (while (/= (cdr (assoc 0 (setq e (entget (setq s (entnext s)))))) "SEQEND") (terpri) (princ (cdr (assoc 10 e))) (setq i (1+ i)) ) ) (and (< 0 i) (princ (strcat "\nThere are total [ " (itoa i) " ] vertices in this object"))) (princ) ) Quote
