BIGAL Posted August 29, 2022 Share Posted August 29, 2022 Try this, Note your dwg has offsets like 22 no where near 1/16 = 0.0625 need a real pline to test. (defun c:del116 ( / ent co-ord start end ss1 ss2 obj obj2 obj3 oldsnap) (setq ent (car (entsel "\nPick pline "))) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent)))) (setq obj (vlax-ename->vla-object ent)) (setq start (vlax-curve-getstartPoint obj)) (setq end (vlax-curve-getEndPoint obj)) (command "line" start end "") (setq obj2 (vlax-ename->vla-object (entlast))) (vla-offset obj2 0.0625) (setq obj3 (vlax-ename->vla-object (entlast))) (setq start (vlax-curve-getstartPoint obj3)) (setq end (vlax-curve-getEndPoint obj3)) (setq ss1 (ssget "F" (list start end) (list (cons 0 "LWPOLYLINE")))) (vla-offset obj2 -0.0625) (setq obj3 (vlax-ename->vla-object (entlast))) (setq start (vlax-curve-getstartPoint obj3)) (setq end (vlax-curve-getEndPoint obj3)) (setq ss2 (ssget "F" (list start end) (list (cons 0 "LWPOLYLINE")))) (if (and (= ss1 nil)(= ss2 nil)) (progn (alert "pline outside range") (vla-delete obj2) ) (progn (alert "pline within range") (command "erase" ent "") ) ) (setvar 'osmode oldsnap) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
stlo Posted August 30, 2022 Author Share Posted August 30, 2022 Hi Bigal! Oh man, this is awesome! Thank you very much! I've tried to add some commands to what you did and it's working! Please let me know if it makes sense to you the way I did it! I found some reading about vla, so much to learn! (defun c:del116 ( / ent co-ord start end ss1 ss2 obj obj2 obj3 obj4 oldsnap) ;;I’ve added obj4 to be able to delete it later;; (command "pedit" "M" (ssget) "" "y" "J" "" "") ;;I realise that I needed to create the polyline before;; (setq ent (car (entsel "\nPick pline "))) (setvar 'osmode 0) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent)))) (setq obj (vlax-ename->vla-object ent)) (setq start (vlax-curve-getstartPoint obj)) (setq end (vlax-curve-getEndPoint obj)) (command "line" start end "") (setq obj2 (vlax-ename->vla-object (entlast))) (vla-offset obj2 0.0625) (setq obj3 (vlax-ename->vla-object (entlast))) (setq start (vlax-curve-getstartPoint obj3)) (setq end (vlax-curve-getEndPoint obj3)) (setq ss1 (ssget "F" (list start end) (list (cons 0 "LWPOLYLINE")))) (vla-offset obj2 -0.0625) (setq obj4 (vlax-ename->vla-object (entlast))) (setq start (vlax-curve-getstartPoint obj4)) (setq end (vlax-curve-getEndPoint obj4)) (setq ss2 (ssget "F" (list start end) (list (cons 0 "LWPOLYLINE")))) (if (and (= ss1 nil)(= ss2 nil)) (progn (alert "pline within range") ;;I’ve switch the order of the within and the without range in the code;; (command "erase" ent "") (vla-delete obj3) ;;deletes the offset lines;; (vla-delete obj4) ;;deletes the offset lines;; ) (progn (alert "pline outside range") (vla-delete obj2) (vla-delete obj3) ;;deletes the offset lines;; (vla-delete obj4) ;;deletes the offset lines;; (command "CHANGE" (entlast) "" "P" "LA" "WALL" "") ;;Change the layer of the new polyline (command "copy" (Entsel) "" '(0 0) '(0 0)) ;;creates a copy on same layer (command "CHANGE" (entlast) "" "P" "LA" "CLIP" "") ;; Change the layer of the new copied polyline ) ) (setvar 'osmode 7679) ;;I’ve set my own number because it stayed on Osmode 0;; (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 30, 2022 Share Posted August 30, 2022 (edited) Glad it works, my bad left a couple of lines out. (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) ............ ........... (setvar 'osmode oldsnap) Edited August 30, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
