eyeofnewt555 Posted June 15, 2016 Posted June 15, 2016 Hey guys! Basically, if there are two identical radii in close proximity, I'd like to be able to use just one dimension rather that two (just to keep things cleaner). From my understanding, you cannot add a second leader to radial dimensions (correct me if I'm wrong), in which case, does anyone know how to: a) Convert existing radial dimensions to multileaders, which I can then add leader lines to OR b) Create a multileader that will prompt to select an arc and then autopopulate the mleader text with the selected radial dimension? Thanks for any help! Liz Quote
BIGAL Posted June 16, 2016 Posted June 16, 2016 You would have to do in 2 parts 1 leader with text and 2nd leader no text, using a lisp that would check the radius as well. Its not something I have. Method pick rad1, pick rad2, pick end pt, drag rotation. Search here for leader using lisp. It gets complicated if the curve is part of a pline. Quote
pkenewell Posted June 16, 2016 Posted June 16, 2016 Use a FIELD with the Multileader to get the radius of the Fillet? Quote
