theinventor87 Posted June 10, 2016 Share Posted June 10, 2016 I am learning Autodesk Inventor and am having trouble adding a certain dimension to a slot to a product I am embedding into a 2D sketch. Attached is a screenshot that portrays the issue I am facing. Thank you in advance for your assistance. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 10, 2016 Share Posted June 10, 2016 Welcome to CADTutor. Sorry I can't answer your question, as I don't use Inventor, but Inventor questions should be posted in the Inventor Forum, thus increasing the likelihood that Inventor users will see them, and respond. If I read your post correctly, it sounds like you haven't modeled the slotted hole into your model? Which seems different than how I would expect it to be done. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 10, 2016 Share Posted June 10, 2016 I moved your thread to the Autodesk Inventor Forum, please post your Inventor questions here from now on. Quote Link to comment Share on other sites More sharing options...
gbradley Posted June 21, 2016 Share Posted June 21, 2016 Use Centered Pattern Good luck! Quote Link to comment Share on other sites More sharing options...
