siyadaliek Posted June 9, 2016 Share Posted June 9, 2016 Is any one know i am having one lips for printing and i want to run this lips to many drawing in my d:\work Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 9, 2016 Share Posted June 9, 2016 I'd recommend using a script to print all your drawings by using a Windows .bat file or use the Scriptpro program from AutoDesk. BTW...it's "lisp" not lips. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 9, 2016 Share Posted June 9, 2016 You could use my Script Writer application. Quote Link to comment Share on other sites More sharing options...
tmelancon Posted June 9, 2016 Share Posted June 9, 2016 For simple printing while in a drawing, a simple lisp tailored to each plotting process needed could be efficient. However, for batch printing from a drive/folder, I recommend lees Script Writer, I use it quite often. Very handy and user friendly! Thanks again Lee! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 9, 2016 Share Posted June 9, 2016 However, for batch printing from a drive/folder, I recommend lees Script Writer, I use it quite often. Very handy and user friendly! Thanks again Lee! I'm delighted to hear that you find it so useful! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 10, 2016 Share Posted June 10, 2016 I had 128 dwg's some with multiple layouts produced 148 pdf's took around 4 secs to do each one using a script that opened the dwg, loaded plot lisp then closes. Yes they were very simple dwgs. Like others Lee helped me with a very simple fix to my script. Quote Link to comment Share on other sites More sharing options...
vorno Posted March 17, 2021 Share Posted March 17, 2021 (edited) Are you able to post your solution please? I want an alternative to PUBLISH as I need to be able to plot a lot of drawings to PDF without having to deal with the inefficiencies of PUBLISH. My problem is that the only solution I've found thus far is a simple plot script that targets individually named layouts - which doesn't work when you have: Multiple drawings with unique layout names. Multiple layouts within each drawing. It has so far been a bit difficult to find a script / LISP solution, more-so to find a solution that doesn't involve opening drawings! I have a company based application that allows for Scripts to run without opening drawings, but nothing for LISP routines - provided the solution I may end up finding is LISP based! Edited March 17, 2021 by vorno Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 17, 2021 Share Posted March 17, 2021 Ok you need to look at Aeccoreconsole it will run without opening drawings. The attached code is for plotting a range of layouts in a dwg so would suit your needs, it would need to be changed slightly to accept the layout range from a script etc. Edit the following. (defun AH:pltlays (numlay numend / lay) (SETVAR "PDMODE" 0) (setvar "fillmode" 1) (setvar "textfill" 1) (setq alllays (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))) (setq count (vla-get-count alllays)) ;(if (not AH:getvalsm)(load "Multi Getvals.lsp")) ;(setq vals (AH:getvalsm (list "Enter plot range" "Enter start tab number" 6 4 "1" "Enter end tab number" 6 4 (RTOS COUNT 2 0)))) ;(setq numlay (atoi (nth 0 vals))) ;(setq numend (atoi (nth 1 vals))) Ok so a typical Aeccoreconsole is ran from a batch file :: Path to AutoCAD core console set accoreexe="C:\Program Files\Autodesk\AutoCAD 2020\accoreconsole.exe" :: Path to the script to run set script="C:\Users\[USERNAME]\Desktop\TESTER\tester2.scr" %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST1.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST2.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST3.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST4.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST5.dwg /s %script% The script file would be (load "plotpdfrange") (AH:pltlays 1 100) plotA3Pdfrange.lsp 1 1 Quote Link to comment Share on other sites More sharing options...
vorno Posted March 18, 2021 Share Posted March 18, 2021 Thanks - I will have to experiment with this and see what I can get to work! So far I seem to need admin permissions to even open Aeccoreconsole - so will see what my work IT can do to accommodate me! Quote Link to comment Share on other sites More sharing options...
MrSmith Posted March 21, 2021 Share Posted March 21, 2021 BIGAL, I don't think that will work with AcCoreConsole. You have vlax commands in the LISP you are trying to call. As far as I know, most ActiveX commands won't work in Core Console unless they are outside of Acad environment, like file system commands (vl-file-delete, etc). For Core Console, you have to use pure AutoCAD commands or LISP commands. Might be able to import them though? I've not tried it. https://www.cadtutor.net/forum/topic/32196-pasting-code/?tab=comments#comment-262036 Quote Link to comment Share on other sites More sharing options...
