iamsiopao Posted June 9, 2016 Posted June 9, 2016 i want my attribute to rotate from 90 to 270 using flip action. but when i added a flip action on my attribute, the action only works on newly inserted blocks. when i created as new text,mtext or attribute inside a block, any flip action doesnt work, and keeps its rotation. how can i make it work?help.dwg Quote
dbroada Posted June 9, 2016 Posted June 9, 2016 I don't have access to AutoCAD so can only guess but a couple of common problems are.... if you revise a block by changing attributes old blocks will not change until after you ATTSYNC the block. attributes must have their locations LOCKED for them to be moved. Quote
