(defun c:sbb(/a b)
 ((setq a 10 b 5)
   (if (> a b)
     (progn (princ a)
(setq a (+ a 5) b (+ b 6))
   ((princ a)(princ))
   ((princ b)(princ))
Edited by SLW210
Added Code Tags
(defun c:sbb ( / a b )
  ;( this isn't required
   (setq a 10 b 5)
   (if (> a b)
           (princ a)
           (princ a)
          ;(princ) This can be replaced by one final (princ)
           this isn't required
           (princ b)
           this isn't required
       ) ;; end progn
   ) ;; end if
   (princ) ;; This can replace the earlier (princ) expressions
   this isn't required
) ;; end defun
Thanks Lee I thought I would give time for Wwx95 to have a go first. Nice touch the ;;defun I often do this for ;if's etc so you can keep count and make sure closing brackets.
Thanks, I am new here, and I changed my code according to your code,is it like this?
(defun c:sbb (/ a b)
   (if (> a b)
           (princ a)
But how can I run it in CAD? Like this?
(setq a 10 b 5)
(sbb a b)
It doesn't work, and told me "error: no function definition: SBB"
Thank you Al :)
(setq a 10 b 5)
(sbb a b)
If you wish to evaluate the function with arguments, you will need to define it in the following way:
(defun sbb ( a b )
   (if (> a b)
           (princ a)
