sadefa Posted June 5, 2016 Posted June 5, 2016 (edited) Hello to all, I have a challenge to place text markers along a polyline. As this polyline represents the trace of an linear object (in my case cable line) I would like to have at every 250m the length from the start of the line represented as "X +YYY", where X is the kilometer and YYY are the meters. Also it would be good to have the length from the start at every vertex. Can anyone help me with this, as I have no knowledge from lisp programing. Regards and thanks in advance! Edited June 5, 2016 by sadefa Quote
Tharwat Posted June 5, 2016 Posted June 5, 2016 Can you show an example with a sample drawing and what are the requested info should be given from a user ? Quote
sadefa Posted June 5, 2016 Author Posted June 5, 2016 (edited) Sorry, I do not have CAD software at the place where I am at right now, but I have an image that shows exactly what I am looking for. Edited June 5, 2016 by sadefa Quote
BIGAL Posted June 6, 2016 Posted June 6, 2016 Sadefa & Tharwat so many versions are already here just search for "chainage" most can be simply changed to reflect the 3+500 Here is one not sure where it came from but it does mention use of + ; chainage lables of pline ;but you can change "+" if you want to anything else, and if you don't want it just change it to "" - empty string (defun div-error (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg) ) (while (> (getvar "cmdactive") 0) (command)) (setq *error* olderror) (princ) ) (defun divplus (len segm / num lst) (setq num (fix (/ len segm))) (setq cnt 0) (while (<= cnt num) (setq tmp (* cnt segm)) (setq lst (append lst (list tmp))) (setq cnt (1+ cnt)) ) (setq delta (- len (last lst))) (if (not (zerop delta)) (setq lst (append lst (list (+ (last lst) delta)))) lst ) ) (defun divminus (len segm / lst) (while (>= len 0.) (setq lst (append lst (list len))) (setq len (- len segm)) ) (if (not (zerop (last lst))) (setq lst (append lst (list 0.0))) ) lst ) (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt ) ) ) ) (defun answer (quest / wshl ans) (or (vl-load-com)) (setq wshl (vlax-get-or-create-object "WScript.Shell")) (setq ans (vlax-invoke-method wshl 'Popup quest 7 "Answer This Question:" vlax-vbYesNo ) ) (vlax-release-object wshl) (cond ((= ans 6) (setq opt T) ) ((= ans 7) (setq opt nil) ) ) opt ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun make-station (bname / acsp adoc atprom attag at_obj blk_obj hgt lay line_obj sfar ) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1) ) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc)) ) (vla-startundomark adoc) (if (not (tblsearch "block" bname)) (progn (setq attag "NUMBER" ;(strcase (getstring "\nAttribute tag : \n")) atprom "NUMBER" ;(strcase (getstring T "\nAttribute prompt : \n")) hgt 1.0 ;(getreal "\nAttribute text height : \n") ) (setq lay (getvar "clayer")) (setvar "clayer" "0") (setvar "attreq" 0) (setq line_obj (vlax-invoke acsp 'Addline '(0. -3. 0.) (list 0. (* hgt 2.) 0.) ) ) (vla-put-color line_obj acred) (setq blk_obj (vla-add (vla-get-blocks adoc) (vlax-3d-point '(0. 0. 0.)) bname ) sfar (vlax-safearray-fill (vlax-make-safearray vlax-vbObject '(0 . 0)) (list line_obj) ) ) (vla-copyobjects adoc sfar blk_obj) ;;; RetVal = object.AddAttribute(Height, Mode, Prompt, InsertionPoint, Tag, Value) (setq at_obj (vla-addattribute blk_obj hgt acattributemodeverify atprom (vlax-3d-point '(0 10. 0.)) attag "0" ) ) (vla-put-rotation at_obj (* pi 1.5)) (vlax-release-object blk_obj) ) (progn (princ "\n\t >> Block does already exist!\n") (princ) ) ) (if (tblsearch "block" bname) T (progn (alert "Impossible to add block") ) ) (setvar "attreq" 1) (setvar "clayer" lay) (vl-catch-all-apply (function (lambda () (vla-delete line_obj))) ) (vla-regen adoc acactiveviewport) (vla-endundomark adoc) (vlax-release-object acsp) (vlax-release-object adoc) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (or (vl-load-com)) (defun C:d10 (/ *error* acsp adoc appd div-error len num olderror pl pt pt_list step util ) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (or appd (setq appd (vla-get-application adoc))) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc) ) ) ) (or util (setq util (vla-get-utility adoc))) (setq olderror *error*) (setq *error* div-error) (if (not (tblsearch "block" "Station")) (make-station "Station") ) (vla-getentity util 'pl 'pt "\nSelect line NEAR OF POINT TO START measure: >>> \n" ) (if pl (progn (setq step 100) (setq opt (answer "Rotate text perpendicularly to pline?")) (if (not step) (setq step 10.) ) (setq len (vlax-curve-getdistatparam pl (vlax-curve-getendparam pl) ) ) (if (< (distance (vlax-safearray->list pt) (vlax-curve-getstartpoint pl) ) (distance (vlax-safearray->list pt) (vlax-curve-getendpoint pl) ) ) (setq pt_list (divplus len step)) (setq pt_list (divminus len step)) ) (setq pt_list (vl-remove-if (function not) (mapcar (function (lambda (x) (vlax-curve-getpointatdist pl x) ) ) pt_list ) ) ) (setq num 0) (mapcar (function (lambda (x / dr ang att_list at blk_obj) (progn (setq ang (alg-ang pl x) ang (cond ((< (/ pi 2) ang (* pi 1.5)) (+ pi ang)) (T ang) ) ) (setq blk_obj (vlax-invoke acsp 'Insertblock x "Station" 5 5 5 ang ) ) (setq att_list (vlax-invoke blk_obj 'Getattributes)) (foreach at att_list (if (eq (vlax-get at 'Tagstring) "NUMBER") (progn (vlax-put at 'Textstring (if (<= num 900.) (strcat "Ch 0+" (if (equal num 0 1e-15) "000" (rtos num 2 0)) "m") (strcat "Ch " (itoa (fix (/ num 1000.))) "+" (if (equal (- num (* (fix (/ num 1000.)) 1000)) 0 1e-15) "000" (rtos (- num (* (fix (/ num 1000.)) 1000)) 2 0)) "m" ) ) ) (if (not opt) (vlax-put at 'Rotation 0) ) (vla-update at) ) ) ) (vla-update blk_obj) (vlax-release-object blk_obj) (setq num (+ num step)) ) ) ) pt_list ) (if (not (vlax-object-released-p pl)) (vlax-release-object pl) ) ) (princ "\nNothing selected try again\n") ) (vla-zoomextents appd) (vla-regen adoc acactiveviewport) (setq *error* olderror div-error nil ) (princ) ) (prompt "\n") (prompt "\n *** Type D10 to execute *** \n") (princ) Quote
